SetWindowToPlot 方法 (ActiveX)
设置用于定义要打印的布局部分的坐标。 支持的平台:仅限 Windows 签名VBA: object.SetWindowToPlot LowerLeft, UpperRight
返回值 (RetVal)无返回值。 言论窗口坐标取自原点。 这些值的单位由属性指定。PaperUnits 该属性必须设置为 才能将这些坐标用于绘图。PlotTypeacWindow 例子VBA: Sub Example_SetWindowToPlot()
' This example allows the user to define an area in the current layout
' and displays a plot preview of the defined area.
' * Note: You have to exit the
' plot preview before the VBA example will stop and control will be returned
Dim point1 As Variant, point2 As Variant
' Get first point in window
point1 = ThisDrawing.Utility.GetPoint(, "Click the lower-left of the window to plot.")
ReDim Preserve point1(0 To 1) ' Change this to a 2D array by removing the Z position
' Get second point in window
point2 = ThisDrawing.Utility.GetPoint(, "Click the upper-right of the window to plot.")
ReDim Preserve point2(0 To 1) ' Change this to a 2D array by removing the Z position
' Send information about window to current layout
ThisDrawing.ActiveLayout.SetWindowToPlot point1, point2
' Read back window information
ThisDrawing.ActiveLayout.GetWindowToPlot point1, point2
MsgBox "Press any key to plot the following window:" & vbCrLf & vbCrLf & _
"Lower Left: " & point1(0) & ", " & point1(1) & vbCrLf & _
"Upper Right: " & point2(0) & ", " & point2(1)
' Be sure to plot a view, not some other plot style
ThisDrawing.ActiveLayout.PlotType = acWindow
' Send Plot To Window
ThisDrawing.ActiveLayout.ConfigName = "DWG to PDF.pc3"
ThisDrawing.Plot.DisplayPlotPreview acFullPreview
可视化 LISP: (vl-load-com)
(defun c:Example_SetWindowToPlot()
;; This example allows the user to define an area in the current layout to plot
;; and displays a plot preview of the defined area.
;; * Note: You will have to exit the plot preview
;; before the VBA example will stop and control will be returned
;; Get first point in window
(setq point1 (vlax-variant-value (vla-GetPoint (vla-get-Utility doc) nil "Click the lower-left of the window to plot.")))
;; Change this to a 2D array by removing the Z position
(setq pointTemp1 (vlax-make-safearray vlax-vbDouble '(0 . 1)))
(vlax-safearray-put-element pointTemp1 0 (vlax-safearray-get-element point1 0))
(vlax-safearray-put-element pointTemp1 1 (vlax-safearray-get-element point1 1))
;; Get second point in window
(setq point2 (vlax-variant-value (vla-GetCorner (vla-get-Utility doc) point1 "Click the upper-right of the window to plot.")))
(setq pointTemp2 (vlax-make-safearray vlax-vbDouble '(0 . 1)))
(vlax-safearray-put-element pointTemp2 0 (vlax-safearray-get-element point2 0))
(vlax-safearray-put-element pointTemp2 1 (vlax-safearray-get-element point2 1))
;; Send information about window to current layout
(vla-SetWindowToPlot (vla-get-ActiveLayout doc) pointTemp1 pointTemp2)
;; Read back window information
(vla-GetWindowToPlot (vla-get-ActiveLayout doc) 'point1 'point2)
(setq point1 (vlax-safearray->list point1)
point2 (vlax-safearray->list point2))
(alert (strcat "Press any key to plot the following window:"
"\nLower Left: " (rtos (nth 0 point1) 2) ", " (rtos (nth 1 point1) 2)
"\nUpper Right: " (rtos (nth 0 point2) 2) ", " (rtos (nth 1 point2) 2)))
;; Make sure the instruction is to plot a view, not some other plot style
(vla-put-PlotType (vla-get-ActiveLayout doc) acWindow)
;; Send Plot To Window - A plot device must be set before a preview can be created
(vla-put-ConfigName (vla-get-ActiveLayout doc) "DWG to PDF.pc3")
(vla-DisplayPlotPreview (vla-get-Plot doc) acFullPreview)
GMT+8, 2026-11-15 12:41
