SetWeight 方法 (ActiveX)
在给定索引处设置控制点的权重。 支持的平台:仅限 Windows 签名VBA: object.SetWeight Index, Weight
返回值 (RetVal)无返回值。 言论没有其他评论。 例子VBA: Sub Example_SetWeight()
' This example creates a spline object in model space.
' It then finds the weight of the first control point
' and changes that value.
' Create the spline
Dim splineObj As AcadSpline
Dim startTan(0 To 2) As Double
Dim endTan(0 To 2) As Double
Dim fitPoints(0 To 8) As Double
startTan(0) = 0.5: startTan(1) = 0.5: startTan(2) = 0
endTan(0) = 0.5: endTan(1) = 0.5: endTan(2) = 0
fitPoints(0) = 1: fitPoints(1) = 1: fitPoints(2) = 0
fitPoints(3) = 5: fitPoints(4) = 5: fitPoints(5) = 0
fitPoints(6) = 10: fitPoints(7) = 0: fitPoints(8) = 0
Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan)
ZoomAll
' Display the coordinates of the first fit point
Dim weight As Double
weight = splineObj.GetWeight(0)
MsgBox "The weight of control point 1 is " & weight, , "SetWeight Example"
' Change the weight of the first control point
weight = 5
splineObj.SetWeight 0, weight
splineObj.Update
MsgBox "The weight of control point 1 is now " & weight, , "SetWeight Example"
可视化 LISP: (vl-load-com)
(defun c:Example_SetWeight()
;; This example creates a spline object in model space.
;; It then finds the weight of the first control point
;; and changes that value.
;; Create the spline
(setq startTan (vlax-3d-point 0.5 0.5 0)
endTan (vlax-3d-point 0.5 0.5 0)
fitPoints (vlax-make-safearray vlax-vbDouble '(0 . 8)))
(vlax-safearray-fill fitPoints '(1 1 0
5 5 0
10 0 0
(setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan))
(vla-ZoomAll acadObj)
;; Display the coordinates of the first fit point
(setq weight (vla-GetWeight splineObj 0))
(alert (strcat "The weight of control point 1 is " (rtos weight 2)))
;; Change the weight of the first control point
(setq weight 5)
(vla-SetWeight splineObj 0 weight)
(vla-Update splineObj)
(alert (strcat "The weight of control point 1 is now " (rtos weight 2)))
GMT+8, 2026-11-15 12:01
