SetView 方法 (ActiveX)
2024-5-18 18:39| 发布者: admin| 查看: 723| 评论: 0|原作者: admin|来自: AutoCAD
将视口中的视图设置为 Views 集合对象中保存的视图。
object.SetView View
类型:视口
此方法应用到的对象。
视图
访问:仅输入
类型: 查看
要设置的视图。
返回值 (RetVal)
无返回值。
Sub Example_SetView()
    ' This example creates a new view.
    ' It then changes the active viewport to
    ' the newly created view.
    ' Create a new view
    Dim viewObj As AcadView
    Set viewObj = ThisDrawing.Views.Add("TESTVIEW")
    ' Set the view characteristics
    viewObj.center(0) = 374: viewObj.center(1) = 313
    viewObj.Width = 450
    viewObj.Height = 354
    ' Get the current active viewport
    Dim viewportObj As AcadViewport
    Set viewportObj = ThisDrawing.ActiveViewport
    MsgBox "Change to the saved view.", , "SetView Example"
    ' Set the view in the viewport
    viewportObj.SetView viewObj
    ThisDrawing.ActiveViewport = viewportObj
    ThisDrawing.Regen True
(defun c:Example_SetView()
    ;; This example creates a new view.
    ;; It then changes the active viewport to
    ;; the newly created view.
    ;; Create a new view
    (setq viewObj (vla-Add (vla-get-Views doc) "TESTVIEW"))
    ;; Set the view characteristics
    (setq centerPoint (vlax-make-safearray vlax-vbDouble '(0 . 1)))
    (vlax-safearray-fill centerPoint '(374 313))
    (vla-put-Center viewObj centerPoint)
    (vla-put-Width viewObj 450)
    (vla-put-height viewObj 354)
    ; Get the current active viewport
    (setq viewportObj (vla-get-ActiveViewport doc))
    (alert "Change to the saved view.")
    ;; Set the view in the viewport
    (vla-SetView viewportObj viewObj)
    (vla-put-ActiveViewport doc viewportObj)
    (vla-Regen doc :vlax-true)
GMT+8, 2026-11-15 11:43
