SetVariable 方法 (ActiveX)
设置 AutoCAD 系统变量的值。 支持的平台:仅限 Windows 签名VBA: object.SetVariable Name, Value
返回值 (RetVal)无返回值。 言论设置系统变量时,AutoCAD 可能需要整数、文本或双精度值。传递错误的数据类型(例如,在需要整数时传递 double 类型的变体)将生成错误。避免这种情况的最简单方法是使用其中一个函数(如 ,在传递数据之前显式键入数据)。CxxxCInt() 有关所有AutoCAD系统变量及其类型的列表,请参见AutoCAD帮助系统中的“系统变量”。 例子VBA: Sub Example_SetVariable()
' This example sets various system variables, each of
' a different data type.
Dim sysVarName As String
Dim sysVarData As Variant
Dim DataType As Integer
' Set FILEDIA system variable (data type Integer) to 1. NOTE that
' you need to declare a variable as the data type of system variable,
' assign data to that variable and then make it variant type
Dim intData As Integer
sysVarName = "FILEDIA"
intData = 1
sysVarData = intData ' Integer data
ThisDrawing.SetVariable sysVarName, sysVarData
' Check the variable using GetVariable
sysVarData = ThisDrawing.GetVariable(sysVarName)
MsgBox sysVarName & " = " & sysVarData, , "SetVariable Example"
' Set DCTCUST system variable (data type String) to "My Custom Dictionary"
Dim strData As String
sysVarName = "DCTCUST"
strData = "My Custom Dictionary"
sysVarData = strData ' String data
' Set CHAMFERA system variable (data type Double) to 1.5
Dim dataDouble As Double
sysVarName = "CHAMFERA"
dataDouble = 1.5
sysVarData = dataDouble ' Double data
' Set INSBASE system variable (data type array) to (1.0,1.0,0)
Dim arrayData3D(0 To 2) As Double
sysVarName = "INSBASE"
arrayData3D(0) = 1#: arrayData3D(1) = 1#: arrayData3D(2) = 0
sysVarData = arrayData3D ' 3D array data
MsgBox sysVarName & " = " & sysVarData(0) & ", " & sysVarData(1) & ", " & sysVarData(2), , "SetVariable Example"
可视化 LISP: (vl-load-com)
(defun c:Example_SetVariable()
;; This example sets various system variables, each of
;; a different data type.
;; Set FILEDIA system variable (data type Integer) to 1. NOTE that
;; you need to declare a variable as the data type of system variable,
;; assign data to that variable and then make it variant type
(setq sysVarName "FILEDIA"
intData 1
sysVarData intData) ;; Integer data
(vla-SetVariable doc sysVarName sysVarData)
;; Check the variable using GetVariable
(setq sysVarData (vlax-variant-value (vla-GetVariable doc sysVarName)))
(alert (strcat sysVarName " = " (itoa sysVarData)))
;; Set DCTCUST system variable (data type String) to "My Custom Dictionary"
(setq sysVarName "DCTCUST"
strData "My Custom Dictionary"
sysVarData strData) ;; String data
(alert (strcat sysVarName " = " sysVarData))
;; Set CHAMFERA system variable (data type Double) to 1.5
(setq sysVarName "CHAMFERA"
dataDouble 1.5
sysVarData dataDouble) ;; Double data
(alert (strcat sysVarName " = " (rtos sysVarData 2)))
;; Set INSBASE system variable (data type array) to (1.0,1.0,0)
(setq sysVarName "INSBASE"
arrayData3D (vlax-3d-point 1 1 0)
sysVarData arrayData3D) ;; 3D array data
(alert (strcat sysVarName " = " (rtos (vlax-safearray-get-element sysVarData 0) 2) ", "
(rtos (vlax-safearray-get-element sysVarData 1) 2) ", "
(rtos (vlax-safearray-get-element sysVarData 2) 2)))
GMT+8, 2026-11-15 11:45
