SetPattern 方法 (ActiveX)
设置填充的图案名称和图案类型。 支持的平台:仅限 Windows 签名VBA: object.SetPattern PatternType, PatternName
返回值 (RetVal)无返回值。 言论填充图案可由以下选项之一定义: PreDefined:从 acad.pat 文件中定义的模式名称中选择模式名称。 UserDefined:使用当前线型定义线条图案。 CustomDefined:从 acad.pat 文件以外的 PAT 文件中选择模式名称。
注意:该方法应仅用于活动文档。SetPattern
例子VBA: Sub Example_SetPattern()
' This example creates an associative hatch in model space.
' The hatch pattern is then changed.
Dim hatchObj As AcadHatch
Dim patternName As String
Dim PatternType As Long
Dim bAssociativity As Boolean
' Define the hatch
patternName = "ANSI31"
PatternType = 0
bAssociativity = True
' Create the associative Hatch object
Set hatchObj = ThisDrawing.ModelSpace.AddHatch(PatternType, patternName, bAssociativity)
' Create the outer loop for the hatch.
' An arc and a line are used to create a closed loop.
Dim outerLoop(0 To 1) As AcadEntity
Dim center(0 To 2) As Double
Dim radius As Double
Dim startAngle As Double
Dim endAngle As Double
center(0) = 5: center(1) = 3: center(2) = 0
radius = 3
startAngle = 0
endAngle = 3.141592
Set outerLoop(0) = ThisDrawing.ModelSpace.AddArc(center, radius, startAngle, endAngle)
Set outerLoop(1) = ThisDrawing.ModelSpace.AddLine(outerLoop(0).startPoint, outerLoop(0).endPoint)
' Append the outer loop to the hatch object
hatchObj.AppendOuterLoop (outerLoop)
' Append the first circle as one inner loop
Dim innerLoop1(0) As AcadEntity
center(0) = 5: center(1) = 4.5: center(2) = 0
radius = 1
Set innerLoop1(0) = ThisDrawing.ModelSpace.AddCircle(center, radius)
hatchObj.AppendInnerLoop (innerLoop1)
' Append the second circle as the other inner loop
Dim innerLoop2(0) As AcadEntity
radius = 0.5
Set innerLoop2(0) = ThisDrawing.ModelSpace.AddCircle(center, radius)
hatchObj.AppendInnerLoop (innerLoop2)
' Evaluate and display the hatch
hatchObj.Evaluate
ZoomAll
' Find the name of the hatch pattern
patternName = hatchObj.patternName
MsgBox "The hatch pattern is " & hatchObj.patternName, , "SetPattern Example"
' Change the hatch pattern
hatchObj.SetPattern acHatchPatternTypePreDefined, "BRICK"
hatchObj.Evaluate
ThisDrawing.Regen True
MsgBox "The hatch pattern is now " & hatchObj.patternName, , "SetPattern Example"
可视化 LISP: (vl-load-com)
(defun c:Example_SetPattern()
;; This example creates an associative hatch in model space.
;; The hatch pattern is then changed.
;; Define the hatch
(setq patternName "ANSI31"
patternType 0
bAssociativity :vlax-true)
;; Create the associative Hatch object
(setq hatchObj (vla-AddHatch modelSpace patternType patternName bAssociativity acHatchObject))
;; Create the outer loop for the hatch.
;; An arc and a line are used to create a closed loop.
(setq center (vlax-3d-point 5 3 0)
radius 3
startAngle 0
endAngle 3.141592)
(setq arc (vla-AddArc modelSpace center radius startAngle endAngle))
(setq line (vla-AddLine modelSpace (vla-get-StartPoint arc) (vla-get-EndPoint arc)))
(setq outerLoop (vlax-make-safearray vlax-vbObject '(0 . 1)))
(vlax-safearray-put-element outerLoop 0 arc)
(vlax-safearray-put-element outerLoop 1 line)
;; Append the outer loop to the hatch object
(vla-AppendOuterLoop hatchObj outerLoop)
;; Append the first circle as one inner loop
(setq center (vlax-3d-point 5 4.5 0)
radius 1)
(setq circle1 (vla-AddCircle modelSpace center radius))
(setq innerLoop1 (vlax-make-safearray vlax-vbObject '(0 . 0)))
(vlax-safearray-put-element innerLoop1 0 circle1)
(vla-AppendInnerLoop hatchObj innerLoop1)
;; Append the second circle as the other inner loop
(setq radius 0.5)
(setq innerLoop2 (vlax-make-safearray vlax-vbObject '(0 . 0)))
(setq circle2 (vla-AddCircle modelSpace center radius))
(vlax-safearray-put-element innerLoop2 0 circle2)
(vla-AppendInnerLoop hatchObj innerLoop2)
;; Evaluate and display the hatch
(vla-Evaluate hatchObj)
(vla-ZoomAll acadObj)
;; Find the name of the hatch pattern
(setq patternName (vla-get-patternName hatchObj))
(alert (strcat "The hatch pattern is " patternName))
;; Change the hatch pattern
(vla-SetPattern hatchObj acHatchPatternTypePreDefined "BRICK")
(vla-Regen doc :vlax-true)
(alert (strcat "The hatch pattern is now " (vla-get-patternName hatchObj)))
GMT+8, 2026-11-15 14:57
