AcAxOleLinkManager
2024-5-18 18:38| 发布者: admin| 查看: 662| 评论: 0|原作者: admin|来自: AutoCAD
AcAxOleLinkManager
AcAxOleLinkManager用于管理从驻留数据库对象到其 COM 对象的链接。这是通过将瞬态电抗器连接到 .瞬态反应器有一个变量,其中包含指向 的 的指针 的 对象。该瞬态电抗器也用于在修改时调用。AcDbObjectIUnknownIAcadBaseObject::OnModified()AcDbObject
AutoCAD 在每个任务中维护一个实例。若要获取指向 OLE 链接管理器的指针,请使用该函数。在 oleaprot.h 文件中声明的类如下所述:AcAxOleLinkManagerAcAxGetOleLinkManager()AcAxOleLinkManager
// AcAxOleLinkManager is used to maintain the link between ARX
// objects and their respective COM wrapper.
class AcAxOleLinkManager
public:
    // Given a pointer to a database-resident object, return
    // the IUnknown of the COM wrapper. NULL is returned if
    // no wrapper is found.
    virtual IUnknown* GetIUnknown(AcDbObject* pObject) = 0;
    // Set the link between a database-resident object and a
    // COM wrapper. If the IUnknown is NULL, then the link
    // is removed.
    virtual Adesk::Boolean SetIUnknown(AcDbObject* pObject,
        IUnknown* pUnknown) = 0;
    // Given a pointer to a database object, return
    virtual IUnknown* GetIUnknown(AcDbDatabase* pDatabase) = 0;
    // Set the link between a database object and a COM wrapper.
    // If the IUnknown is NULL, then the link is removed.
    virtual Adesk::Boolean SetIUnknown(AcDbDatabase* pDatabase,
    // Given a pointer to a database object, return the
    // IDispatch of the document object. NULL is returned if
    // the database does not belong to a particular document.
    virtual IDispatch* GetDocIDispatch(AcDbDatabase* pDatabase)= 0;
    // Set the link between a database object and the IDispatch
    // of the document it belongs to. If the IDispatch is NULL, then
    // the link is removed.
    virtual Adesk::Boolean SetDocIDispatch(AcDbDatabase* pDatabase,
        IDispatch* pDispatch) = 0;
GMT+8, 2026-11-25 15:29
