AcGe 持久性示例
2024-5-18 18:38| 发布者: admin| 查看: 731| 评论: 0|原作者: admin|来自: AutoCAD
AcGe 持久性示例
以下是具有具体子类的 的读取和写入示例。在本示例中,序列化文件管理器是 DWG 文件管理器。因此,它通过读取和写入 DWG 格式来提供持久性:AcGeExternalSurfaceAcGeFiler
#include "gefiler.h"
class AcDbDwgFiler;
class AcGeDwgFiler : public AcGeFiler
public:
// Construct the filer with DWG filer.
// All read and write methods are implemented
// by delegating to this filer.
    AcGeDwgFiler (AcDbDwgFiler* = NULL);
    // Read/write methods.
    Acad::ErrorStatus      readBoolean(Adesk::Boolean*);
    Acad::ErrorStatus      writeBoolean(Adesk::Boolean);
    Acad::ErrorStatus      readBool(bool*);
    Acad::ErrorStatus      writeBool(bool);
    Acad::ErrorStatus      readChar(char*);
    Acad::ErrorStatus      writeChar(char);
    Acad::ErrorStatus      readShort(short*);
    Acad::ErrorStatus      writeShort(short);
    Acad::ErrorStatus      readLong(long*);
    Acad::ErrorStatus      writeLong(long);
    Acad::ErrorStatus      readUChar(unsigned char*);
    Acad::ErrorStatus      writeUChar(unsigned char);
    Acad::ErrorStatus      readUShort(unsigned short*);
    Acad::ErrorStatus      writeUShort(unsigned short);
    Acad::ErrorStatus      readULong(unsigned long*);
    Acad::ErrorStatus      writeULong(unsigned long);
    Acad::ErrorStatus      readDouble(double*);
    Acad::ErrorStatus      writeDouble(double);
    Acad::ErrorStatus      readPoint2d(AcGePoint2d*);
    Acad::ErrorStatus      writePoint2d(const AcGePoint2d&);
    Acad::ErrorStatus      readPoint3d(AcGePoint3d*);
    Acad::ErrorStatus      writePoint3d(const AcGePoint3d&);
    Acad::ErrorStatus      readVector2d(AcGeVector2d*);
    Acad::ErrorStatus      writeVector2d(const AcGeVector2d&);
    Acad::ErrorStatus      readVector3d(AcGeVector3d*);
    Acad::ErrorStatus      writeVector3d(const AcGeVector3d&);
    // Set/Get methods
    AcGeDwgFiler&    setDwgFiler     (AcDbDwgFiler*);
    AcDbDwgFiler*    dwgFiler        ();
protected:
    AcDbDwgFiler*    mpFiler;
// Inline methods.
inline
AcGeDwgFiler::AcGeDwgFiler(AcDbDwgFiler* filer) : mpFiler(filer)
inline AcGeDwgFiler&
AcGeDwgFiler::setDwgFiler(AcDbDwgFiler* filer)
    mpFiler = filer;
    return *this;
inline AcDbDwgFiler*
AcGeDwgFiler::dwgFiler()
    return mpFiler;
下一个代码片段演示了几个函数的实现。其他函数以相同的方式实现:
Acad::ErrorStatus AcGeDwgFiler::readBoolean(Adesk::Boolean* data)
    return mpFiler ? mpFiler->readBoolean(data) : Acad::eNoDatabase;
Acad::ErrorStatus AcGeDwgFiler::writeBoolean(Adesk::Boolean data)
    return mpFiler ?
	mpFiler->writeBoolean(data) : Acad::eNoDatabase;
下一个示例演示一个使用 .类声明后面的代码说明了外表面类的读取和写入。特别要注意的是 AcGeExternalSurface
AcGe::gLibVersion在写入或读取外表面类之前先写出,然后先读取:
class AcGeExternalCurve2d;
class AcGeExternalCurve3d;
class AcGeExternalBoundedSurface;
class AcGeExternalSurface;
class  AcGePersistentXEnt : public AcDbObject
public:
    ACRX_DECLARE_MEMBERS (AcGePersistentXEnt);
    AcGePersistentXEnt ();
    ~AcGePersistentXEnt ();
    Acad::ErrorStatus dwgOutFields (AcDbDwgFiler*) const;
    Acad::ErrorStatus dwgInFields  (AcDbDwgFiler*);
    AcGeExternalSurface*           mpXSrf;
此类的实现如下:
ACRX_DXF_DEFINE_MEMBERS(
    AcGePersistentXEnt, AcDbObject, AcDb::kDHL_CURRENT,
    AcDb::kMReleaseCurrent, 0, GEPERSISTENT, "GeometryLib");
Acad::ErrorStatus
AcGePersistentXEnt::dwgOutFields(AcDbDwgFiler* filer) const
    assertReadEnabled();
    Acad::ErrorStatus stat = AcDbObject::dwgOutFields(filer);
    if (stat != Acad::eOk)
        ADS_ASSERT(0);
        return stat;
    // Only interested in a file filer.
    if (filer->filerType() != AcDb::kFileFiler)
        return stat;
    AcGeDwgFiler   geDwgFiler(filer);
    stat = AcGeFileIO::outFields(
        &geDwgFiler,
        AcGe::gLibVersion);
    if ((stat = AcGeFileIO::outFields(&geDwgFiler,
        *mpXSrf)) != Acad::eOk)
        return stat;
    return stat;
Acad::ErrorStatus
AcGePersistentXEnt::dwgInFields(AcDbDwgFiler* filer)
    assertWriteEnabled();
    Acad::ErrorStatus stat = AcDbObject::dwgInFields(filer);
        ADS_ASSERT(0);
        return stat;
        return stat;
    AcGeLibVersion  gelibVersion;
    if ((stat = AcGeFileIO::inFields(&geDwgFiler,
        gelibVersion)) != Acad::eOk)
        return stat;
    acutPrintf("\n... Reading External Surface\n");
    mpXSrf = new AcGeExternalSurface;
    ADS_ASSERT(mpXSrf);
        *mpXSrf, gelibVersion))  != Acad::eOk)
        return stat;
    return stat;
  1. 持久性 AcGe 实体
GMT+8, 2026-10-17 21:40
