数据链路代码示例
2024-5-18 18:37| 发布者: admin| 查看: 929| 评论: 0|原作者: admin|来自: AutoCAD
数据链路代码示例
下面的代码示例提供了一种方法,说明如何正确设计代码以将 AutoCAD 表格数据链接到 Excel 电子表格。此处的示例假定文件的名称为“Sheet 1”。
// Create a data link and set it to the cell(2,2) of a selected table.
void createAndSetDataLink()
	// Select a table
	AcDbTable *pTbl = NULL;
	if(NULL == (pTbl =
	AcDbTable::cast(selectEntity(_T("\nSelect a table: ")))))
		acutPrintf(ACRX_T("\nSelected entity was not a table!"));
		return;
	// Get an Excel file
	struct resbuf *result;
	int rc;
	if ( (result = acutNewRb(RTSTR)) == NULL)
		pTbl->close();
		acutPrintf(ACRX_T("\nUnable to allocate buffer!"));
		return;
	result->resval.rstring=NULL;
	rc = acedGetFileD(ACRX_T("Excel File"),	// Title
						ACRX_T("c:/temp"),	// Default pathname
						ACRX_T("xls"),	//Default extension
						16,					// Control flags
						result);	// The path selected by the user.
	if (rc != RTNORM)
		pTbl->close();
		acutPrintf(ACRX_T("\nError in selecting an EXCEL file!"));
		return;
	// Retrieve the file name from the ResBuf.
	ACHAR fileName[MAX_PATH];
	_tcscpy(fileName, result->resval.rstring);
	rc = acutRelRb(result);
	static ACHAR sMyDataLink[MAX_PATH] = ACRX_T("MyDataLinkTest");
	// Get the Data Link Manager.
	Acad::ErrorStatus es;
	AcDbDataLinkManager* pDlMan = acdbHostApplicationServices()->workingDatabase()->getDataLinkManager();
	assert(pDlMan);
	AcDbObjectId idDL;
	AcDbDataLink *pDL = NULL;
	// Check if a Data Link with the name already exists. If so, remove it.
	if( pDlMan->getDataLink(sMyDataLink, pDL, AcDb::kForRead) == Acad::eOk && pDL)
		pDL->close();
		es = pDlMan->removeDataLink(sMyDataLink, idDL);
		if( es != Acad::eOk )
			pTbl->close();
			acutPrintf(ACRX_T("\nError in removing the Data Link!"));
			return;
	// Create the Data Link with the name.
	es = pDlMan->createDataLink(ACRX_T("AcExcel"), sMyDataLink, ACRX_T("This is a test for Excel type data link."), fileName, idDL);
		pTbl->close();
		acutPrintf(ACRX_T("\nError in creating Data Link!\nPlease check if there is a sheet named 'Sheet1' in the XLS file."));
		return;
	// Open the Data Link.
	es = acdbOpenObject<AcDbDataLink>(pDL, idDL, AcDb::kForWrite);
	if ( es != Acad::eOk || !pDL )
		pTbl->close();
		acutPrintf(ACRX_T("\nError in opening the Data Link object!"));
		return;
	//  Set options of the Data Link
	es = pDL->setOption(AcDb::kDataLinkOptionPersistCache);
	es = pDL->setUpdateOption(pDL->updateOption() | AcDb::kUpdateOptionAllowSourceUpdate);
	// Close the Data Link.
	pDL->close();
	// Set data link to the table object at cell(2,2).
	es = pTbl->setDataLink(2, 2, idDL, true);
		pTbl->close();
		acutPrintf(ACRX_T("\nError in setting Data Link to the selected table!\nPlease check if there is a sheet named 'Sheet1' in the XLS file."));
		return;
	// Don't forget to close the table object.
	es = pTbl->close();
  1. 操作数据
GMT+8, 2026-10-16 04:56
