实现对象捕捉点功能
2024-5-18 18:37| 发布者: admin| 查看: 794| 评论: 0|原作者: admin|来自: AutoCAD
实现对象捕捉点功能
如果希望自定义实体支持对象捕捉模式,则需要覆盖该函数。AutoCAD 调用以获取当前模式的相关捕捉点,然后调用该捕捉点以访问自定义图元的捕捉模式。如果不希望实体支持特定模式的捕捉点,则可以筛选出支持的捕捉模式,并返回其他模式;系统将提示用户再次选择。如果多个对象捕捉模式处于活动状态,则对每个对象捕捉模式调用一次此函数。subGetOsnapPoints()getOsnapPoints()subGetOsnapPoints()eOk
注意:交集对象捕捉模式的处理方式与 不同。它使用 ,而不是 。getOsnapPoints()AcDbEntity::intersectWith()getOsnapPoints()
下面显示了该类如何实现该函数:AsdkPolysubGetOsnapPoints()
 Acad::ErrorStatus
 AsdkPoly::subGetOsnapPoints(
     AcDb::OsnapMode       osnapMode,
     Adesk::GsMarker       gsSelectionMark,
     const AcGePoint3d&    pickPoint,
     const AcGePoint3d&    lastPoint,
     const AcGeMatrix3d&   viewXform,
     AcGePoint3dArray&     snapPoints,
     AcDbIntArray&         /*geomIds*/) const
     assertReadEnabled();
     Acad::ErrorStatus es = Acad::eOk;
     if (gsSelectionMark == 0)
         return Acad::eOk;
     if (   osnapMode != AcDb::kOsModeEnd
         && osnapMode != AcDb::kOsModeMid
         && osnapMode != AcDb::kOsModeNear
         && osnapMode != AcDb::kOsModePerp
         && osnapMode != AcDb::kOsModeCen
         && osnapMode != AcDb::kOsModeIns)
         return Acad::eOk;
     // First, check to see if the gsSelection marker is the
     // text geometry. If so, handle center and insertion
     // modes, then return. No need to go into perp, mid, etc.
     AcGePoint3d center;
     getCenter(center);
     if (gsSelectionMark == (mNumSides + 1)) {
         if (osnapMode == AcDb::kOsModeIns)
             snapPoints.append(center);
         else if (osnapMode == AcDb::kOsModeCen)
         return es;
     int startIndex = (int)(gsSelectionMark - 1);
     AcGePoint3dArray vertexArray;
     if ((es = getVertices3d(vertexArray)) != Acad::eOk) {
         return es;
     AcGeLineSeg3d lnsg(vertexArray[startIndex],
             vertexArray[startIndex + 1]);
     AcGePoint3d pt;
     AcGeLine3d line, perpLine;
     AcGeVector3d vec;
     AcGeVector3d viewDir(viewXform(Z, 0), viewXform(Z, 1),
             viewXform(Z, 2));
     switch (osnapMode) {
     case AcDb::kOsModeEnd:
         snapPoints.append(vertexArray[startIndex]);
         snapPoints.append(vertexArray[startIndex + 1]);
         break;
     case AcDb::kOsModeMid:
         pt.set(
             ((vertexArray[startIndex])[X]
                 + (vertexArray[startIndex + 1])[X]) * 0.5,
             ((vertexArray[startIndex])[Y]
                 + (vertexArray[startIndex + 1])[Y]) * 0.5,
             ((vertexArray[startIndex])[Z]
                 + (vertexArray[startIndex + 1])[Z]) * 0.5);
         snapPoints.append(pt);
         break;
     case AcDb::kOsModeNear:
         pt = lnsg.projClosestPointTo(pickPoint, viewDir);
         break;
     case AcDb::kOsModePerp:
         // Create a semi-infinite line and find a point on it.
         vec = vertexArray[startIndex + 1]
             - vertexArray[startIndex];
         vec.normalize();
         line.set(vertexArray[startIndex], vec);
         pt = line.closestPointTo(lastPoint);
         break;
     case AcDb::kOsModeCen:
         break;
     default:
         return Acad::eOk;
     return es;
GMT+8, 2026-11-30 10:58
