创建字典
下面的示例创建一个新字典 (ASDK_DICT) 并将其添加到命名对象字典中。然后,它创建自定义类的两个新对象(派生自 ),并使用该函数将它们添加到字典中。AsdkMyClassAcDbObjectsetAt() 注意:使用函数添加对象后,您需要关闭对象。setAt()
// This function creates two objects of class AsdkMyClass.
// It fills them in with the integers 1 and 2, and then adds
// them to the dictionary associated with the key ASDK_DICT. If this
// dictionary doesn't exist, it is created and added to the named
// object dictionary.
void
createDictionary()
AcDbDictionary *pNamedobj;
acdbHostApplicationServices()->workingDatabase()->
getNamedObjectsDictionary(pNamedobj, AcDb::kForWrite);
// Check to see if the dictionary we want to create is
// already present. If not, create it and add
// it to the named object dictionary.
AcDbDictionary *pDict;
if (pNamedobj->getAt("ASDK_DICT", (AcDbObject*&) pDict,
AcDb::kForWrite) == Acad::eKeyNotFound)
pDict = new AcDbDictionary;
AcDbObjectId DictId;
pNamedobj->setAt("ASDK_DICT", pDict, DictId);
pNamedobj->close();
if (pDict) {
// Create new objects to add to the new dictionary,
// add them, then close them.
AsdkMyClass *pObj1 = new AsdkMyClass(1);
AsdkMyClass *pObj2 = new AsdkMyClass(2);
AcDbObjectId rId1, rId2;
pDict->setAt("OBJ1", pObj1, rId1);
pDict->setAt("OBJ2", pObj2, rId2);
pObj1->close();
pObj2->close();
pDict->close();
父主题: |
GMT+8, 2026-10-18 23:13
