创建简单块表记录
2024-5-18 18:37| 发布者: admin| 查看: 783| 评论: 0|原作者: admin|来自: AutoCAD
创建简单块表记录
下面的示例演示如何创建新的块表记录并将其追加到块表中。然后,它创建一行并将其附加到新的块表记录中。
void
makeABlock()
     // Create and name a new block table record.
     AcDbBlockTableRecord *pBlockTableRec
         = new AcDbBlockTableRecord();
     pBlockTableRec->setName("ASDK-NO-ATTR");
     // Get the block table.
     AcDbBlockTable *pBlockTable = NULL;
     acdbHostApplicationServices()->workingDatabase()
        ->getSymbolTable(pBlockTable, AcDb::kForWrite);
     // Add the new block table record to the block table.
     AcDbObjectId blockTableRecordId;
     pBlockTable->add(blockTableRecordId, pBlockTableRec);
     pBlockTable->close();
     // Create and add a line entity to the component's
     // block record.
     AcDbLine *pLine = new AcDbLine();
     AcDbObjectId lineId;
     pLine->setStartPoint(AcGePoint3d(3, 3, 0));
     pLine->setEndPoint(AcGePoint3d(6, 6, 0));
     pLine->setColorIndex(3);
     pBlockTableRec->appendAcDbEntity(lineId, pLine);
     pLine->close();
     pBlockTableRec->close();
GMT+8, 2026-10-28 02:42
