ObjectARX 扩展字典示例
下面的示例演示如何实例化 xrecord 并将其添加到命名对象字典中的扩展字典中: void
createXrecord()
AcDbXrecord *pXrec = new AcDbXrecord;
AcDbObject *pObj;
AcDbObjectId dictObjId, xrecObjId;
AcDbDictionary* pDict;
pObj = selectObject(AcDb::kForWrite);
if (pObj == NULL) {
return;
// Try to create an extension dictionary for this
// object. If the extension dictionary already exists,
// this will be a no-op.
pObj->createExtensionDictionary();
// Get the object ID of the extension dictionary for the
// selected object.
dictObjId = pObj->extensionDictionary();
pObj->close();
// Open the extension dictionary and add the new
// xrecord to it.
acdbOpenObject(pDict, dictObjId, AcDb::kForWrite);
pDict->setAt("ASDK_XREC1", pXrec, xrecObjId);
pDict->close();
// Create a resbuf list to add to the xrecord.
struct resbuf* head;
ads_point testpt = {1.0, 2.0, 0.0};
head = acutBuildList(AcDb::kDxfText,
"This is a test Xrecord list",
AcDb::kDxfXCoord, testpt,
AcDb::kDxfReal, 3.14159,
AcDb::kDxfAngle, 3.14159,
AcDb::kDxfColor, 1,
AcDb::kDxfInt16, 180,
0);
// Add the data list to the xrecord. Notice that this
// member function takes a reference to a resbuf NOT a
// pointer to a resbuf, so you must dereference the
// pointer before sending it.
pXrec->setFromRbChain(*head);
pXrec->close();
acutRelRb(head);
// The listXrecord() function gets the xrecord associated with the
// key "ASDK_XREC1" and lists out its contents by passing the resbuf
// list to the function printList().
void
listXrecord()
AcDbObject *pObj;
AcDbXrecord *pXrec;
AcDbObjectId dictObjId;
AcDbDictionary *pDict;
pObj = selectObject(AcDb::kForRead);
if (pObj == NULL) {
return;
// Get the object ID of the object's extension dictionary.
pObj->close();
// Open the extension dictionary and get the xrecord
// associated with the key ASDK_XREC1.
acdbOpenObject(pDict, dictObjId, AcDb::kForRead);
pDict->getAt("ASDK_XREC1", (AcDbObject*&)pXrec,
AcDb::kForRead);
pDict->close();
// Get the xrecord's data list and then close the xrecord.
struct resbuf *pRbList;
pXrec->rbChain(&pRbList);
pXrec->close();
printList(pRbList);
acutRelRb(pRbList);
父主题: |
GMT+8, 2026-11-29 11:05
