错误处理
2024-5-18 18:37| 发布者: admin| 查看: 632| 评论: 0|原作者: admin|来自: AutoCAD
错误处理
本指南中的示例省略了必要的错误检查,以简化代码。但是,您始终需要检查退货状态并采取适当的措施。以下示例演示了对数据库入门中首先显示的几个示例的错误检查的正确使用。
Acad::ErrorStatus createCircle(AcDbObjectId& circleId)
    circleId = AcDbObjectId::kNull;
    AcGePoint3d center(9.0, 3.0, 0.0);
    AcGeVector3d normal(0.0, 0.0, 1.0);
    AcDbCircle *pCirc = new AcDbCircle(center, normal, 2.0);
    if (pCirc == NULL)
        return Acad::eOutOfMemory;
    AcDbBlockTable *pBlockTable;
    Acad::ErrorStatus es =
        acdbHostApplicationServices()->workingDatabase()->
            getSymbolTable(pBlockTable, AcDb::kForRead);
    if (es != Acad::eOk) {
        delete pCirc;
        return es;
    AcDbBlockTableRecord *pBlockTableRecord;
    es = pBlockTable->getAt(ACDB_MODEL_SPACE,
        pBlockTableRecord, AcDb::kForWrite);
        Acad::ErrorStatus es2 = pBlockTable->close();
        if (es2 != Acad::eOk) {
            acrx_abort("\nApp X failed to close Block"
                " Table. Error: %d",
                acadErrorStatusText(es2));
        delete pCirc;
        return es;
    es = pBlockTable->close();
        acrx_abort("\nApp X failed to close Block Table."
            " Error: %d", acadErrorStatusText(es));
    es = pBlockTableRecord->appendAcDbEntity(circleId,
        pCirc);
        Acad::ErrorStatus es2 = pBlockTableRecord->close();
            acrx_abort("\nApp X failed to close"
                " Model Space Block Record. Error: %s",
        delete pCirc;
        return es;
    es = pBlockTableRecord->close();
            " Model Space Block Record. Error: %d",
    es = pCirc->close();
        acrx_abort("\nApp X failed to"
            " close circle entity. Error: %d",
    return es;
Acad::ErrorStatus createNewLayer()
    AcDbLayerTableRecord *pLayerTableRecord
        = new AcDbLayerTableRecord;
    if (pLayerTableRecord == NULL)
        = pLayerTableRecord->setName("ASDK_MYLAYER");
        delete pLayerTableRecord;
        return es;
    AcDbLayerTable *pLayerTable;
    es = acdbHostApplicationServices()->workingDatabase()->
        getSymbolTable(pLayerTable, AcDb::kForWrite);
        return es;
    // The linetype object ID default is 0, which is
    // not a valid ID.  Therefore, it must be set to a
    // valid ID, the CONTINUOUS linetype.
    // Other data members have valid defaults, so
    // they can be left alone.
    AcDbLinetypeTable *pLinetypeTbl;
        getSymbolTable(pLinetypeTbl, AcDb::kForRead);
        es = pLayerTable->close();
            acrx_abort("\nApp X failed to close Layer"
        return es;
    AcDbObjectId ltypeObjId;
    es = pLinetypeTbl->getAt("CONTINUOUS", ltypeObjId);
        return es;
    pLayerTableRecord->setLinetypeObjectId(ltypeObjId);
    es = pLayerTable->add(pLayerTableRecord);
        Acad::ErrorStatus es2 = pLayerTable->close();
        return es;
    es = pLayerTableRecord->close();
            " Table Record. Error: %d",
    return es;
GMT+8, 2026-11-29 23:45
