将组添加到组字典
2024-5-18 18:37| 发布者: admin| 查看: 912| 评论: 0|原作者: admin|来自: AutoCAD
将组添加到组字典
下面的代码在 and 函数中创建的线和圆之外创建一个组 (),并将该组放入 GROUP 字典中。直线和圆的对象 ID 将传递到函数中。请注意 GROUP 字典是如何打开写入、修改和显式关闭的。pGroupcreateLine()createCircle()
void
createGroup(AcDbObjectIdArray& objIds, char* pGroupName)
    AcDbGroup *pGroup = new AcDbGroup(pGroupName);
    // Put the group in the group dictionary which resides
    // in the named object dictionary.
    AcDbDictionary *pGroupDict;
    acdbHostApplicationServices()->workingDatabase()
        ->getGroupDictionary(pGroupDict, AcDb::kForWrite);
    AcDbObjectId pGroupId;
    pGroupDict->setAt(pGroupName, pGroup, pGroupId);
    pGroupDict->close();
    // Now that the group has been added, it has an ObjectID.
    // This is important since the group will become a persistent
    // reactor for the added entities...
    for (int i = 0; i < objIds.length(); i++) {
        pGroup->append(objIds[i]);
    pGroup->close();
GMT+8, 2026-10-28 04:41
