视觉样式 (.NET)
视觉样式允许您控制对象在屏幕上和输出过程中的显示方式。视觉样式作为视觉样式字典的一部分存储在图形中,并且它们都可以自定义。由于所有视觉样式都可以自定义,因此不能期望每个图形都包含所有标准视觉样式,这些样式是AutoCAD附带的图形模板的一部分。视觉样式由类表示。DBVisualStyle 列出可用的视觉样式本示例列出存储在当前图形中的可视样式。 VB.NETImports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.Colors
Imports Autodesk.AutoCAD.GraphicsInterface
' Lists the available visual styles
<CommandMethod("ListVisualStyle")> _
Public Shared Sub ListVisualStyle()
' Get the current document and database, and start a transaction
Dim vStyles As DBDictionary = _
acTrans.GetObject(acCurDb.VisualStyleDictionaryId, _
OpenMode.ForRead)
' Output a message to the Command Line history
acDoc.Editor.WriteMessage(vbLf & "Visual styles: ")
' Step through the dictionary
For Each entry As DBDictionaryEntry In vStyles
' Get the dictionary entry
Dim vStyle As DBVisualStyle = _
vStyles.GetAt(entry.Key).GetObject(OpenMode.ForRead)
' If the visual style is not marked for internal use then output its name
If vStyle.InternalUseOnly = False Then
' Output the name of the visual style
acDoc.Editor.WriteMessage(vbLf & " " & vStyle.Name)
End If
Next
End Using
using Autodesk.AutoCAD.Colors;
using Autodesk.AutoCAD.GraphicsInterface;
// Lists the available visual styles
[CommandMethod("ListVisualStyle")]
public static void ListVisualStyle()
// Get the current document and database, and start a transaction
DBDictionary vStyles = acTrans.GetObject(acCurDb.VisualStyleDictionaryId,
OpenMode.ForRead) as DBDictionary;
// Output a message to the Command Line history
acDoc.Editor.WriteMessage("\nVisual styles: ");
// Step through the dictionary
foreach (DBDictionaryEntry entry in vStyles)
// Get the dictionary entry
DBVisualStyle vStyle = vStyles.GetAt(entry.Key).GetObject(OpenMode.ForRead) as DBVisualStyle;
// If the visual style is not marked for internal use then output its name
if (vStyle.InternalUseOnly == false)
// Output the name of the visual style
acDoc.Editor.WriteMessage("\n " + vStyle.Name);
创建或编辑视觉样式此示例创建或编辑名为 MyVS 的视觉样式。 VB.NETImports Autodesk.AutoCAD.Runtime
' Creates a new visual style
<CommandMethod("CreateVisualStyle")> _
Public Shared Sub CreateVisualStyle()
OpenMode.ForRead)
Try
' Check to see if the "MyVS" exists or not
If vStyles.Contains("MyVS") = True Then
vStyle = acTrans.GetObject(vStyles.GetAt("MyVS"), _
OpenMode.ForWrite)
Else
acTrans.GetObject(acCurDb.VisualStyleDictionaryId, OpenMode.ForWrite)
' Create the visual style
vStyle = New DBVisualStyle
vStyles.SetAt("MyVS", vStyle)
' Add the visual style to the dictionary
acTrans.AddNewlyCreatedDBObject(vStyle, True)
End If
' Set the description of the visual style
vStyle.Description = "My Visual Style"
vStyle.Type = VisualStyleType.Custom
' Face Settings (Opacity, Face Style, Lighting Quality, Color,
' Monochrome color, Opacity, and Material Display)
vStyle.SetTrait(VisualStyleProperty.FaceModifier, _
VSFaceModifiers.FaceOpacityFlag, _
VisualStyleOperation.Set)
vStyle.SetTrait(VisualStyleProperty.FaceLightingModel, _
VSFaceLightingModel.Gooch, _
vStyle.SetTrait(VisualStyleProperty.FaceLightingQuality, _
VSFaceLightingQuality.PerPixelLighting, _
vStyle.SetTrait(VisualStyleProperty.FaceColorMode, _
VSFaceColorMode.ObjectColor, _
vStyle.SetTrait(VisualStyleProperty.FaceMonoColor, _
Color.FromColorIndex(ColorMethod.ByAci, 1), _
vStyle.SetTrait(VisualStyleProperty.FaceOpacity, 0.5, _
vStyle.SetTrait(VisualStyleProperty.DisplayStyle, _
VSDisplayStyles.MaterialsFlag + _
VSDisplayStyles.TexturesFlag, _
' Lighting (Enable Highlight Intensity,
' Highlight Intensity, and Shadow Display)
vStyle.GetTrait(VisualStyleProperty.FaceModifier) + _
VSFaceModifiers.SpecularFlag, _
vStyle.GetTrait(VisualStyleProperty.DisplayStyle) + _
VSDisplayStyles.LightingFlag, _
vStyle.SetTrait(VisualStyleProperty.FaceSpecular, _
45.0, VisualStyleOperation.Set)
vStyle.SetTrait(VisualStyleProperty.DisplayShadowType, _
VSDisplayShadowType.Full, _
' Environment Settings (Backgrounds)
VSDisplayStyles.BackgroundsFlag, _
' Edge Settings (Show, Number of Lines, Color, and Always on Top)
vStyle.SetTrait(VisualStyleProperty.EdgeModel, VSEdgeModel.Isolines, _
vStyle.SetTrait(VisualStyleProperty.EdgeIsolines, _
6, VisualStyleOperation.Set)
vStyle.SetTrait(VisualStyleProperty.EdgeColor, _
Color.FromColorIndex(ColorMethod.ByAci, 2), _
vStyle.SetTrait(VisualStyleProperty.EdgeModifier, _
vStyle.GetTrait(VisualStyleProperty.EdgeModifier) + _
VSEdgeModifiers.AlwaysOnTopFlag, _
' Occluded Edges (Show, Color, and Linetype)
If Not (vStyle.GetTrait(VisualStyleProperty.EdgeStyle) And _
VSEdgeStyles.ObscuredFlag) > 0 Then
vStyle.SetTrait(VisualStyleProperty.EdgeStyle, _
vStyle.GetTrait(VisualStyleProperty.EdgeStyle) + _
VSEdgeStyles.ObscuredFlag, _
End If
vStyle.SetTrait(VisualStyleProperty.EdgeObscuredColor, _
Color.FromColorIndex(ColorMethod.ByAci, 3), _
vStyle.SetTrait(VisualStyleProperty.EdgeObscuredLinePattern, _
VSEdgeLinePattern.DoubleMediumDash, _
' Intersection Edges (Color and Linetype)
VSEdgeStyles.IntersectionFlag) > 0 Then
VSEdgeStyles.IntersectionFlag, _
End If
vStyle.SetTrait(VisualStyleProperty.EdgeIntersectionColor, _
Color.FromColorIndex(ColorMethod.ByAci, 4), _
vStyle.SetTrait(VisualStyleProperty.EdgeIntersectionLinePattern, _
VSEdgeLinePattern.ShortDash, _
' Silhouette Edges (Color and Width)
VSEdgeStyles.SilhouetteFlag) > 0 Then
VSEdgeStyles.SilhouetteFlag, _
End If
vStyle.SetTrait(VisualStyleProperty.EdgeSilhouetteColor, _
Color.FromColorIndex(ColorMethod.ByAci, 5), _
vStyle.SetTrait(VisualStyleProperty.EdgeSilhouetteWidth, 2, _
' Edge Modifiers (Enable Line Extensions, Enable Jitter,
' Line Extensions, Jitter, Crease Angle,
' and Halo Gap)
If Not (vStyle.GetTrait(VisualStyleProperty.EdgeModifier) And _
VSEdgeModifiers.EdgeOverhangFlag) > 0 Then
VSEdgeModifiers.EdgeOverhangFlag, _
End If
VSEdgeModifiers.EdgeJitterFlag) > 0 Then
VSEdgeModifiers.EdgeJitterFlag, _
End If
vStyle.SetTrait(VisualStyleProperty.EdgeOverhang, 3, _
vStyle.SetTrait(VisualStyleProperty.EdgeJitterAmount, _
VSEdgeJitterAmount.JitterMedium, _
vStyle.SetTrait(VisualStyleProperty.EdgeCreaseAngle, _
0.3, VisualStyleOperation.Set)
vStyle.SetTrait(VisualStyleProperty.EdgeHaloGap, _
5, VisualStyleOperation.Set)
Catch es As Autodesk.AutoCAD.Runtime.Exception
MsgBox(es.Message)
Finally
acTrans.Commit()
End Try
End Using
// Creates a new visual style
[CommandMethod("CreateVisualStyle")]
public static void CreateVisualStyle()
try
// Check to see if the "MyVS" exists or not
DBVisualStyle vStyle = default(DBVisualStyle);
if (vStyles.Contains("MyVS") == true)
vStyle = acTrans.GetObject(vStyles.GetAt("MyVS"), OpenMode.ForWrite) as DBVisualStyle;
else
acTrans.GetObject(acCurDb.VisualStyleDictionaryId, OpenMode.ForWrite);
// Create the visual style
vStyle = new DBVisualStyle();
vStyles.SetAt("MyVS", vStyle);
// Add the visual style to the dictionary
acTrans.AddNewlyCreatedDBObject(vStyle, true);
// Set the description of the visual style
vStyle.Description = "My Visual Style";
vStyle.Type = VisualStyleType.Custom;
// Face Settings (Opacity, Face Style, Lighting Quality, Color,
// Monochrome color, Opacity, and Material Display)
vStyle.SetTrait(VisualStyleProperty.FaceModifier, (int)VSFaceModifiers.FaceOpacityFlag, VisualStyleOperation.Set);
vStyle.SetTrait(VisualStyleProperty.FaceLightingModel, (int)VSFaceLightingModel.Gooch, VisualStyleOperation.Set);
vStyle.SetTrait(VisualStyleProperty.FaceLightingQuality, (int)VSFaceLightingQuality.PerPixelLighting, VisualStyleOperation.Set);
vStyle.SetTrait(VisualStyleProperty.FaceColorMode, (int)VSFaceColorMode.ObjectColor, VisualStyleOperation.Set);
vStyle.SetTrait(VisualStyleProperty.FaceMonoColor, Color.FromColorIndex(ColorMethod.ByAci, 1), VisualStyleOperation.Set);
vStyle.SetTrait(VisualStyleProperty.FaceOpacity, 0.5, VisualStyleOperation.Set);
vStyle.SetTrait(VisualStyleProperty.DisplayStyle, (int)VSDisplayStyles.MaterialsFlag + (int)VSDisplayStyles.TexturesFlag, VisualStyleOperation.Set);
// Lighting (Enable Highlight Intensity,
// Highlight Intensity, and Shadow Display)
vStyle.SetTrait(VisualStyleProperty.FaceModifier, (int)vStyle.GetTrait(VisualStyleProperty.FaceModifier) + (int)VSFaceModifiers.SpecularFlag, VisualStyleOperation.Set);
vStyle.SetTrait(VisualStyleProperty.DisplayStyle, (int)vStyle.GetTrait(VisualStyleProperty.DisplayStyle) + (int)VSDisplayStyles.LightingFlag, VisualStyleOperation.Set);
vStyle.SetTrait(VisualStyleProperty.FaceSpecular, 45.0, VisualStyleOperation.Set);
vStyle.SetTrait(VisualStyleProperty.DisplayShadowType, (int)VSDisplayShadowType.Full, VisualStyleOperation.Set);
// Environment Settings (Backgrounds)
vStyle.SetTrait(VisualStyleProperty.DisplayStyle, (int)vStyle.GetTrait(VisualStyleProperty.DisplayStyle) + (int)VSDisplayStyles.BackgroundsFlag, VisualStyleOperation.Set);
// Edge Settings (Show, Number of Lines, Color, and Always on Top)
vStyle.SetTrait(VisualStyleProperty.EdgeModel, (int)VSEdgeModel.Isolines, VisualStyleOperation.Set);
vStyle.SetTrait(VisualStyleProperty.EdgeIsolines, 6, VisualStyleOperation.Set);
vStyle.SetTrait(VisualStyleProperty.EdgeColor, Color.FromColorIndex(ColorMethod.ByAci, 2), VisualStyleOperation.Set);
vStyle.SetTrait(VisualStyleProperty.EdgeModifier, (int)vStyle.GetTrait(VisualStyleProperty.EdgeModifier) + (int)VSEdgeModifiers.AlwaysOnTopFlag, VisualStyleOperation.Set);
// Occluded Edges (Show, Color, and Linetype)
if (!(((int)vStyle.GetTrait(VisualStyleProperty.EdgeStyle) + (int)VSEdgeStyles.ObscuredFlag) > 0))
vStyle.SetTrait(VisualStyleProperty.EdgeStyle, (int)vStyle.GetTrait(VisualStyleProperty.EdgeStyle) + (int)VSEdgeStyles.ObscuredFlag, VisualStyleOperation.Set);
vStyle.SetTrait(VisualStyleProperty.EdgeObscuredColor, Color.FromColorIndex(ColorMethod.ByAci, 3), VisualStyleOperation.Set);
vStyle.SetTrait(VisualStyleProperty.EdgeObscuredLinePattern, (int)VSEdgeLinePattern.DoubleMediumDash, VisualStyleOperation.Set);
// Intersection Edges (Color and Linetype)
if (!(((int)vStyle.GetTrait(VisualStyleProperty.EdgeStyle) + (int)VSEdgeStyles.IntersectionFlag) > 0))
vStyle.SetTrait(VisualStyleProperty.EdgeStyle, (int)vStyle.GetTrait(VisualStyleProperty.EdgeStyle) + (int)VSEdgeStyles.IntersectionFlag, VisualStyleOperation.Set);
vStyle.SetTrait(VisualStyleProperty.EdgeIntersectionColor, Color.FromColorIndex(ColorMethod.ByAci, 4), VisualStyleOperation.Set);
vStyle.SetTrait(VisualStyleProperty.EdgeIntersectionLinePattern, (int)VSEdgeLinePattern.ShortDash, VisualStyleOperation.Set);
// Silhouette Edges (Color and Width)
if (!(((int)vStyle.GetTrait(VisualStyleProperty.EdgeStyle) + (int)VSEdgeStyles.SilhouetteFlag) > 0))
vStyle.SetTrait(VisualStyleProperty.EdgeStyle, (int)vStyle.GetTrait(VisualStyleProperty.EdgeStyle) + (int)VSEdgeStyles.SilhouetteFlag, VisualStyleOperation.Set);
vStyle.SetTrait(VisualStyleProperty.EdgeSilhouetteColor, Color.FromColorIndex(ColorMethod.ByAci, 5), VisualStyleOperation.Set);
vStyle.SetTrait(VisualStyleProperty.EdgeSilhouetteWidth, 2, VisualStyleOperation.Set);
// Edge Modifiers (Enable Line Extensions, Enable Jitter,
// Line Extensions, Jitter, Crease Angle,
// and Halo Gap)
if (!(((int)vStyle.GetTrait(VisualStyleProperty.EdgeModifier) + (int)VSEdgeModifiers.EdgeOverhangFlag) > 0))
vStyle.SetTrait(VisualStyleProperty.EdgeModifier, (int)vStyle.GetTrait(VisualStyleProperty.EdgeModifier) + (int)VSEdgeModifiers.EdgeOverhangFlag, VisualStyleOperation.Set);
if (!(((int)vStyle.GetTrait(VisualStyleProperty.EdgeModifier) + (int)VSEdgeModifiers.EdgeJitterFlag) > 0))
vStyle.SetTrait(VisualStyleProperty.EdgeModifier, (int)vStyle.GetTrait(VisualStyleProperty.EdgeModifier) + (int)VSEdgeModifiers.EdgeJitterFlag, VisualStyleOperation.Set);
vStyle.SetTrait(VisualStyleProperty.EdgeOverhang, 3, VisualStyleOperation.Set);
vStyle.SetTrait(VisualStyleProperty.EdgeJitterAmount, (int)VSEdgeJitterAmount.JitterMedium, VisualStyleOperation.Set);
vStyle.SetTrait(VisualStyleProperty.EdgeCreaseAngle, 0.3, VisualStyleOperation.Set);
vStyle.SetTrait(VisualStyleProperty.EdgeHaloGap, 5, VisualStyleOperation.Set);
catch (Autodesk.AutoCAD.Runtime.Exception es)
System.Windows.Forms.MessageBox.Show(es.Message);
finally
acTrans.Commit();
父主题: |
GMT+8, 2026-10-17 12:18
