分离外部参照 (.NET)
2024-5-18 18:37| 发布者: admin| 查看: 783| 评论: 0|原作者: admin|来自: AutoCAD
分离外部参照 (.NET)
可以分离外部参照定义,以从图形中完全移除外部参照。您还可以擦除单个外部参照实例。分离外部参照定义将移除与该外部参照关联的所有从属符号。如果从图形中清除了外部参照的所有实例,则 AutoCAD 将在下次打开图形时移除外部参照定义。
若要分离外部参照,请使用以下方法。不能分离嵌套外部参照。DetachXref
分离外部参照定义
本示例附加外部参照,然后分离外部参照。此示例使用在 Sample 目录中找到的 Exterior Elevations.dwg 文件。如果您没有此映像,或者它位于其他目录中,请插入有效的路径和文件名。
VB.NET
<CommandMethod("DetachingExternalReference")> _
Public Sub DetachingExternalReference()
    ' Get the current database and start a transaction
    Dim acCurDb As Autodesk.AutoCAD.DatabaseServices.Database
    acCurDb = Application.DocumentManager.MdiActiveDocument.Database
        ' Create a reference to a DWG file
        Dim PathName As String = "C:\AutoCAD\Sample\Sheet Sets\Architectural\Res\Exterior Elevations.dwg"
        Dim acXrefId As ObjectId = acCurDb.AttachXref(PathName, "Exterior Elevations")
        ' If a valid reference is created then continue
        If Not acXrefId.IsNull Then
            ' Attach the DWG reference to the current space
            Dim insPt As New Point3d(1, 1, 0)
            Using acBlkRef As New BlockReference(insPt, acXrefId)
                acBlkTblRec = acTrans.GetObject(acCurDb.CurrentSpaceId, OpenMode.ForWrite)
                acBlkTblRec.AppendEntity(acBlkRef)
                acTrans.AddNewlyCreatedDBObject(acBlkRef, True)
            End Using
            MsgBox("The external reference is attached.")
            acCurDb.DetachXref(acXrefId)
            MsgBox("The external reference is detached.")
        End If
        ' Save the new objects to the database
        acTrans.Commit()
        ' Dispose of the transaction
    End Using
C#
[CommandMethod("DetachingExternalReference")]
public void DetachingExternalReference()
    // Get the current database and start a transaction
    Database acCurDb;
    acCurDb = Application.DocumentManager.MdiActiveDocument.Database;
        // Create a reference to a DWG file
        string PathName = "C:\\AutoCAD\\Sample\\Sheet Sets\\Architectural\\Res\\Exterior Elevations.dwg";
        ObjectId acXrefId = acCurDb.AttachXref(PathName, "Exterior Elevations");
        // If a valid reference is created then continue
        if (!acXrefId.IsNull)
            // Attach the DWG reference to the current space
            Point3d insPt = new Point3d(1, 1, 0);
            using (BlockReference acBlkRef = new BlockReference(insPt, acXrefId))
                BlockTableRecord acBlkTblRec;
                acBlkTblRec = acTrans.GetObject(acCurDb.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord;
                acBlkTblRec.AppendEntity(acBlkRef);
                acTrans.AddNewlyCreatedDBObject(acBlkRef, true);
            Application.ShowAlertDialog("The external reference is attached.");
            acCurDb.DetachXref(acXrefId);
            Application.ShowAlertDialog("The external reference is detached.");
        // Save the new objects to the database
        acTrans.Commit();
        // Dispose of the transaction
VBA/ActiveX 代码参考
    ' Define external reference to be inserted
    Dim xrefInserted As AcadExternalReference
    Dim insertionPnt(0 To 2) As Double
    insertionPnt(0) = 1
    insertionPnt(1) = 1
    insertionPnt(2) = 0
    PathName = "C:\AutoCAD\Sample\Sheet Sets\Architectural\Res\Exterior Elevations.dwg"
    ' Add the external reference
    Set xrefInserted = ThisDrawing.ActiveLayout.Block. _
    AttachExternalReference(PathName, "Exterior Elevations", insertionPnt, 1, 1, 1, 0, False)
    MsgBox "The external reference is attached."
    ' Detach the external reference definition
    Dim name As String
    name = xrefInserted.name
    ThisDrawing.Blocks.Item(name).Detach
    MsgBox "The external reference is detached."
GMT+8, 2026-10-17 04:49
