编辑 3D 实体 (.NET)
2024-5-18 18:36| 发布者: admin| 查看: 964| 评论: 0|原作者: admin|来自: AutoCAD
编辑 3D 实体 (.NET)
创建实体后,可以通过组合或减去实体来创建更复杂的形状。您可以连接实体、相互减去实体或求实体的公共体积(重叠部分)。使用该方法执行这些组合。该方法允许您确定两个实体是否重叠。BooleanOperationCheckInterference
通过获得实体的 2D 横截面或将实体切成两块来进一步修改实体。使用该方法求固体的横截面,以及将实体切成两块的方法。GetSectionSlice
求出两个实体之间的干涉
本示例创建一个方框和圆柱体。然后,它找到两个固体之间的干涉,并从该干涉中创建一个新的固体。为了便于查看,盒子是白色的,圆柱体是青色的,干涉固体是红色的。
VB.NET
<CommandMethod("FindInterferenceBetweenSolids")> _
Public Sub FindInterferenceBetweenSolids()
    '' Get the current document and database, and start a transaction
        Dim acBlkTbl As BlockTable
                                     OpenMode.ForRead)
                                        OpenMode.ForWrite)
        '' Create a 3D solid box
        Using acSol3DBox As Solid3d = New Solid3d()
            acSol3DBox.CreateBox(5, 7, 10)
            acSol3DBox.ColorIndex = 7
            '' Position the center of the 3D solid at (5,5,0)
            acSol3DBox.TransformBy(Matrix3d.Displacement(New Point3d(5, 5, 0) - _
                                                         Point3d.Origin))
            acBlkTblRec.AppendEntity(acSol3DBox)
            acTrans.AddNewlyCreatedDBObject(acSol3DBox, True)
            '' Create a 3D solid cylinder
            '' 3D solids are created at (0,0,0) so there is no need to move it
            Using acSol3DCyl As Solid3d = New Solid3d()
                acSol3DCyl.CreateFrustum(20, 5, 5, 5)
                acSol3DCyl.ColorIndex = 4
                acBlkTblRec.AppendEntity(acSol3DCyl)
                acTrans.AddNewlyCreatedDBObject(acSol3DCyl, True)
                '' Create a 3D solid from the interference of the box and cylinder
                Dim acSol3DCopy As Solid3d = acSol3DCyl.Clone()
                '' Check to see if the 3D solids overlap
                If acSol3DCopy.CheckInterference(acSol3DBox) = True Then
                    acSol3DCopy.BooleanOperation(BooleanOperationType.BoolIntersect, _
                                                 acSol3DBox.Clone())
                    acSol3DCopy.ColorIndex = 1
                End If
                acBlkTblRec.AppendEntity(acSol3DCopy)
                acTrans.AddNewlyCreatedDBObject(acSol3DCopy, True)
            End Using
        End Using
        '' Save the new objects to the database
        acTrans.Commit()
    End Using
C#
[CommandMethod("FindInterferenceBetweenSolids")]
public static void FindInterferenceBetweenSolids()
    // Get the current document and database, and start a transaction
        // Open the Block table record for read
        BlockTable acBlkTbl;
        BlockTableRecord acBlkTblRec;
        // Create a 3D solid box
        using (Solid3d acSol3DBox = new Solid3d())
            acSol3DBox.CreateBox(5, 7, 10);
            acSol3DBox.ColorIndex = 7;
            // Position the center of the 3D solid at (5,5,0)
            acSol3DBox.TransformBy(Matrix3d.Displacement(new Point3d(5, 5, 0) -
                                                            Point3d.Origin));
            acBlkTblRec.AppendEntity(acSol3DBox);
            acTrans.AddNewlyCreatedDBObject(acSol3DBox, true);
            // Create a 3D solid cylinder
            // 3D solids are created at (0,0,0) so there is no need to move it
            using (Solid3d acSol3DCyl = new Solid3d())
                acSol3DCyl.CreateFrustum(20, 5, 5, 5);
                acSol3DCyl.ColorIndex = 4;
                acBlkTblRec.AppendEntity(acSol3DCyl);
                acTrans.AddNewlyCreatedDBObject(acSol3DCyl, true);
                // Create a 3D solid from the interference of the box and cylinder
                Solid3d acSol3DCopy = acSol3DCyl.Clone() as Solid3d;
                // Check to see if the 3D solids overlap
                if (acSol3DCopy.CheckInterference(acSol3DBox) == true)
                                                    acSol3DBox.Clone() as Solid3d);
                    acSol3DCopy.ColorIndex = 1;
                acBlkTblRec.AppendEntity(acSol3DCopy);
                acTrans.AddNewlyCreatedDBObject(acSol3DCopy, true);
        // Save the new objects to the database
        acTrans.Commit();
VBA/ActiveX 代码参考
    ' Define the box
    Dim boxObj As Acad3DSolid
    Dim length As Double
    Dim width As Double
    Dim height As Double
    Dim center(0 To 2) As Double
    center(0) = 5: center(1) = 5: center(2) = 0
    length = 5
    width = 7
    height = 10
    ' Create the box object in model space
    ' and color it white
    Set boxObj = ThisDrawing.ModelSpace. _
                     AddBox(center, length, width, height)
    boxObj.Color = acWhite
    ' Define the cylinder
    Dim cylinderObj As Acad3DSolid
    Dim cylinderRadius As Double
    Dim cylinderHeight As Double
    center(0) = 0: center(1) = 0: center(2) = 0
    cylinderRadius = 5
    cylinderHeight = 20
    ' Create the Cylinder and
    ' color it cyan
    Set cylinderObj = ThisDrawing.ModelSpace. _
                          AddCylinder(center, cylinderRadius, cylinderHeight)
    cylinderObj.Color = acCyan
    ' Find the interference between the two solids
    ' and create a new solid from it. Color the
    ' new solid red.
    Dim solidObj As Acad3DSolid
    Set solidObj = boxObj.CheckInterference(cylinderObj, True)
    solidObj.Color = acRed
    ZoomAll
将固体切成两个固体
本示例在模型空间中创建一个框。然后,它根据由三个点定义的平面对盒子进行切片。切片以 3DSolid 的形式返回。
VB.NET
<CommandMethod("SliceABox")> _
Public Sub SliceABox()
                                     OpenMode.ForRead)
                                        OpenMode.ForWrite)
        Using acSol3D As Solid3d = New Solid3d()
            acSol3D.CreateBox(5, 7, 10)
            acSol3D.ColorIndex = 7
            acSol3D.TransformBy(Matrix3d.Displacement(New Point3d(5, 5, 0) - _
                                                      Point3d.Origin))
            acBlkTblRec.AppendEntity(acSol3D)
            acTrans.AddNewlyCreatedDBObject(acSol3D, True)
            '' Define the mirror plane
            Dim acPlane As Plane = New Plane(New Point3d(1.5, 7.5, 0), _
                                   New Point3d(1.5, 7.5, 10), _
                                   New Point3d(8.5, 2.5, 10))
            Dim acSol3DSlice As Solid3d = acSol3D.Slice(acPlane, True)
            acSol3DSlice.ColorIndex = 1
            acBlkTblRec.AppendEntity(acSol3DSlice)
            acTrans.AddNewlyCreatedDBObject(acSol3DSlice, True)
        End Using
        acTrans.Commit()
    End Using
C#
[CommandMethod("SliceABox")]
public static void SliceABox()
        using (Solid3d acSol3D = new Solid3d())
            acSol3D.CreateBox(5, 7, 10);
            acSol3D.ColorIndex = 7;
            acSol3D.TransformBy(Matrix3d.Displacement(new Point3d(5, 5, 0) -
                                                        Point3d.Origin));
            acBlkTblRec.AppendEntity(acSol3D);
            acTrans.AddNewlyCreatedDBObject(acSol3D, true);
            // Define the mirror plane
            Plane acPlane = new Plane(new Point3d(1.5, 7.5, 0),
                                        new Point3d(1.5, 7.5, 10),
                                        new Point3d(8.5, 2.5, 10));
            Solid3d acSol3DSlice = acSol3D.Slice(acPlane, true);
            acSol3DSlice.ColorIndex = 1;
            acBlkTblRec.AppendEntity(acSol3DSlice);
            acTrans.AddNewlyCreatedDBObject(acSol3DSlice, true);
        acTrans.Commit();
VBA/ActiveX 代码参考
Sub SliceABox()
    Dim width As Double
    center(0) = 5#: center(1) = 5#: center(2) = 0
    length = 5#: width = 7: height = 10#
    ' Create the box (3DSolid) object in model space
    ' Define the section plane with three points
    Dim slicePt1(0 To 2) As Double
    Dim slicePt2(0 To 2) As Double
    Dim slicePt3(0 To 2) As Double
    slicePt1(0) = 1.5: slicePt1(1) = 7.5: slicePt1(2) = 0
    slicePt2(0) = 1.5: slicePt2(1) = 7.5: slicePt2(2) = 10
    slicePt3(0) = 8.5: slicePt3(1) = 2.5: slicePt3(2) = 10
    ' slice the box and color the new solid red
    Dim sliceObj As Acad3DSolid
    Set sliceObj = boxObj.SliceSolid _
                          (slicePt1, slicePt2, slicePt3, True)
    sliceObj.Color = acRed
    ZoomAll
GMT+8, 2026-11-17 07:46
