沿平面镜像对象 (.NET)
2024-5-18 18:36| 发布者: admin| 查看: 816| 评论: 0|原作者: admin|来自: AutoCAD
沿平面镜像对象 (.NET)
使用对象的方法和 Matrix 的方法,可以沿着由三个点指定的指定镜像平面镜像对象。TransformByMirroring
3D镜像
本示例在模型空间中创建一个框。然后,它将盒子镜像到一个平面上,并将镜像的盒子涂成红色。
VB.NET
<CommandMethod("MirrorABox3D")> _
Public Sub MirrorABox3D()
    '' Get the current document and database, and start a transaction
        Dim acBlkTbl As BlockTable
                                     OpenMode.ForRead)
                                        OpenMode.ForWrite)
        '' Create a 3D solid box
        Using acSol3D As Solid3d = New Solid3d()
            acSol3D.CreateBox(5, 7, 10)
            '' Position the center of the 3D solid at (5,5,0)
            acSol3D.TransformBy(Matrix3d.Displacement(New Point3d(5, 5, 0) - _
                                                      Point3d.Origin))
            acBlkTblRec.AppendEntity(acSol3D)
            acTrans.AddNewlyCreatedDBObject(acSol3D, True)
            '' Create a copy of the original 3D solid and change the color of the copy
            Dim acSol3DCopy As Solid3d = acSol3D.Clone()
            acSol3DCopy.ColorIndex = 1
            '' Define the mirror plane
            Dim acPlane As Plane = New Plane(New Point3d(1.25, 0, 0), _
                                             New Point3d(1.25, 2, 0), _
                                             New Point3d(1.25, 2, 2))
            '' Mirror the 3D solid across the plane
            acSol3DCopy.TransformBy(Matrix3d.Mirroring(acPlane))
            acBlkTblRec.AppendEntity(acSol3DCopy)
            acTrans.AddNewlyCreatedDBObject(acSol3DCopy, True)
        End Using
        '' Save the new objects to the database
        acTrans.Commit()
    End Using
C#
[CommandMethod("MirrorABox3D")]
public static void MirrorABox3D()
    // Get the current document and database, and start a transaction
        // Open the Block table record for read
        BlockTable acBlkTbl;
        BlockTableRecord acBlkTblRec;
        // Create a 3D solid box
        using (Solid3d acSol3D = new Solid3d())
            acSol3D.CreateBox(5, 7, 10);
            // Position the center of the 3D solid at (5,5,0)
            acSol3D.TransformBy(Matrix3d.Displacement(new Point3d(5, 5, 0) -
                                                        Point3d.Origin));
            acBlkTblRec.AppendEntity(acSol3D);
            acTrans.AddNewlyCreatedDBObject(acSol3D, true);
            // Create a copy of the original 3D solid and change the color of the copy
            Solid3d acSol3DCopy = acSol3D.Clone() as Solid3d;
            acSol3DCopy.ColorIndex = 1;
            // Define the mirror plane
            Plane acPlane = new Plane(new Point3d(1.25, 0, 0),
                                        new Point3d(1.25, 2, 0),
                                        new Point3d(1.25, 2, 2));
            // Mirror the 3D solid across the plane
            acSol3DCopy.TransformBy(Matrix3d.Mirroring(acPlane));
            acBlkTblRec.AppendEntity(acSol3DCopy);
            acTrans.AddNewlyCreatedDBObject(acSol3DCopy, true);
        // Save the new objects to the database
        acTrans.Commit();
VBA/ActiveX 代码参考
Sub MirrorABox3D()
    ' Create the box object
    Dim boxObj As Acad3DSolid
    Dim length As Double
    Dim width As Double
    Dim height As Double
    Dim center(0 To 2) As Double
    center(0) = 5#: center(1) = 5#: center(2) = 0
    length = 5#: width = 7: height = 10#
    ' Create the box (3DSolid) object in model space
    Set boxObj = ThisDrawing.ModelSpace. _
                     AddBox(center, length, width, height)
    ' Define the mirroring plane with three points
    Dim mirrorPt1(0 To 2) As Double
    Dim mirrorPt2(0 To 2) As Double
    Dim mirrorPt3(0 To 2) As Double
    mirrorPt1(0) = 1.25: mirrorPt1(1) = 0: mirrorPt1(2) = 0
    mirrorPt2(0) = 1.25: mirrorPt2(1) = 2: mirrorPt2(2) = 0
    mirrorPt3(0) = 1.25: mirrorPt3(1) = 2: mirrorPt3(2) = 2
    ' Mirror the box
    Dim mirrorBoxObj As Acad3DSolid
    Set mirrorBoxObj = boxObj.Mirror3D _
                          (mirrorPt1, mirrorPt2, mirrorPt3)
    mirrorBoxObj.Color = acRed
    ZoomAll
GMT+8, 2026-10-24 09:35
