创建几何公差 (.NET)
您可以通过创建对象的实例来创建几何公差。创建对象的实例时,其构造函数可以接受一组可选的参数。创建新对象时,可以提供以下参数:FeatureControlFrameFeatureControlFrameFeatureControlFrame
创建几何公差此示例在模型空间中创建一个简单的几何公差。 VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("CreateGeometricTolerance")> _
Public Sub CreateGeometricTolerance()
'' Get the current database
'' Start a transaction
Dim acBlkTbl As BlockTable
OpenMode.ForRead)
OpenMode.ForWrite)
'' Create the Geometric Tolerance (Feature Control Frame)
Using acFcf As FeatureControlFrame = New FeatureControlFrame()
acFcf.Text = "{\Fgdt;j}%%v{\Fgdt;n}0.001%%v%%v%%v%%v"
acFcf.Location = New Point3d(5, 5, 0)
'' Add the new object to Model space and the transaction
acBlkTblRec.AppendEntity(acFcf)
acTrans.AddNewlyCreatedDBObject(acFcf, True)
End Using
'' Commit the changes and dispose of the transaction
acTrans.Commit()
End Using
[CommandMethod("CreateGeometricTolerance")]
public static void CreateGeometricTolerance()
// Get the current database
// Start a transaction
BlockTable acBlkTbl;
BlockTableRecord acBlkTblRec;
// Create the Geometric Tolerance (Feature Control Frame)
using (FeatureControlFrame acFcf = new FeatureControlFrame())
acFcf.Text = "{\\Fgdt;j}%%v{\\Fgdt;n}0.001%%v%%v%%v%%v";
acFcf.Location = new Point3d(5, 5, 0);
// Add the new object to Model space and the transaction
acBlkTblRec.AppendEntity(acFcf);
acTrans.AddNewlyCreatedDBObject(acFcf, true);
// Commit the changes and dispose of the transaction
acTrans.Commit();
VBA/ActiveX 代码参考Sub CreateGeometricTolerance()
Dim toleranceObj As AcadTolerance
Dim textString As String
Dim direction(0 To 2) As Double
' Define the tolerance object
textString = "{\Fgdt;j}%%v{\Fgdt;n}0.001%%v%%v%%v%%v"
insertionPoint(0) = 5
insertionPoint(1) = 5
insertionPoint(2) = 0
direction(0) = 1
direction(1) = 0
direction(2) = 0
' Create the tolerance object in model space
Set toleranceObj = ThisDrawing.ModelSpace. _
AddTolerance(textString, insertionPoint, direction)
ZoomAll
相关概念父主题: |
GMT+8, 2026-11-29 11:08
