创建引线 (.NET)
2024-5-18 18:36| 发布者: admin| 查看: 766| 评论: 0|原作者: admin|来自: AutoCAD
创建引线 (.NET)
可以从图形中的任何点或特征创建引线并控制其外观。引线可以是直线段或平滑样条曲线。引线颜色由当前尺寸线颜色控制。引线刻度由活动维度样式中设置的整体维度刻度控制。箭头的类型和大小(如果存在)由活动样式中定义的箭头控制。
一条称为钩线的小线通常将注释连接到引线。如果最后一个引线段与水平线的角度大于 15 度,则挂钩线将显示多行文本和要素控制框。钩线是单个箭头的长度。如果引线没有注释,则它没有钩线。
您可以通过创建 Leader 对象的实例来创建 Leader。创建 Leader 对象的实例时,其构造函数不接受任何参数。该方法用于定义所创建引线的位置和长度。AppendVertex
创建引线
本示例在模型空间中创建引线。没有与引线关联的注释。
VB.NET
<CommandMethod("CreateLeader")> _
Public Sub CreateLeader()
    '' Get the current database
    '' Start a transaction
        Dim acBlkTbl As BlockTable
                                     OpenMode.ForRead)
                                        OpenMode.ForWrite)
        '' Create the leader
        Using acLdr As Leader = New Leader()
            acLdr.AppendVertex(New Point3d(0, 0, 0))
            acLdr.AppendVertex(New Point3d(4, 4, 0))
            acLdr.AppendVertex(New Point3d(4, 5, 0))
            acLdr.HasArrowHead = True
            '' Add the new object to Model space and the transaction
            acBlkTblRec.AppendEntity(acLdr)
            acTrans.AddNewlyCreatedDBObject(acLdr, True)
        End Using
        '' Commit the changes and dispose of the transaction
        acTrans.Commit()
    End Using
C#
[CommandMethod("CreateLeader")]
public static void CreateLeader()
    // Get the current database
    // Start a transaction
        BlockTable acBlkTbl;
        BlockTableRecord acBlkTblRec;
        // Create the leader
        using (Leader acLdr = new Leader())
            acLdr.AppendVertex(new Point3d(0, 0, 0));
            acLdr.AppendVertex(new Point3d(4, 4, 0));
            acLdr.AppendVertex(new Point3d(4, 5, 0));
            acLdr.HasArrowHead = true;
            // Add the new object to Model space and the transaction
            acBlkTblRec.AppendEntity(acLdr);
            acTrans.AddNewlyCreatedDBObject(acLdr, true);
        // Commit the changes and dispose of the transaction
        acTrans.Commit();
VBA/ActiveX 代码参考
Sub CreateLeader()
    Dim leaderObj As AcadLeader
    Dim points(0 To 8) As Double
    Dim leaderType As Integer
    Dim annotationObject As AcadObject
    points(0) = 0: points(1) = 0: points(2) = 0
    points(3) = 4: points(4) = 4: points(5) = 0
    points(6) = 4: points(7) = 5: points(8) = 0
    leaderType = acLineWithArrow
    Set annotationObject = Nothing
    ' Create the leader object in model space
    Set leaderObj = ThisDrawing.ModelSpace. _
                        AddLeader(points, annotationObject, leaderType)
    ZoomAll
GMT+8, 2026-10-17 22:55
