重写维度文本 (.NET)
可以使用该属性替换显示的维度值。使用此属性,可以完全替换维度的显示值,也可以将文本追加到该值。要在覆盖维度文本中表示测量值,请在文本中使用字符串“<>”。DimensionText 修改尺寸文本本示例将一些文本追加到值中,以便同时显示字符串和维度值。 VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("OverrideDimensionText")> _
Public Sub OverrideDimensionText()
'' Get the current database
'' Start a transaction
Dim acBlkTbl As BlockTable
OpenMode.ForRead)
OpenMode.ForWrite)
'' Create the aligned dimension
Using acAliDim As AlignedDimension = New AlignedDimension()
acAliDim.XLine1Point = New Point3d(5, 3, 0)
acAliDim.XLine2Point = New Point3d(10, 3, 0)
acAliDim.DimLinePoint = New Point3d(7.5, 5, 0)
acAliDim.DimensionStyle = acCurDb.Dimstyle
'' Override the dimension text
acAliDim.DimensionText = "The value is <>"
'' Add the new object to Model space and the transaction
acBlkTblRec.AppendEntity(acAliDim)
acTrans.AddNewlyCreatedDBObject(acAliDim, True)
End Using
'' Commit the changes and dispose of the transaction
acTrans.Commit()
End Using
[CommandMethod("OverrideDimensionText")]
public static void OverrideDimensionText()
// Get the current database
// Start a transaction
BlockTable acBlkTbl;
BlockTableRecord acBlkTblRec;
// Create the aligned dimension
using (AlignedDimension acAliDim = new AlignedDimension())
acAliDim.XLine1Point = new Point3d(5, 3, 0);
acAliDim.XLine2Point = new Point3d(10, 3, 0);
acAliDim.DimLinePoint = new Point3d(7.5, 5, 0);
acAliDim.DimensionStyle = acCurDb.Dimstyle;
// Override the dimension text
acAliDim.DimensionText = "The value is <>";
// Add the new object to Model space and the transaction
acBlkTblRec.AppendEntity(acAliDim);
acTrans.AddNewlyCreatedDBObject(acAliDim, true);
// Commit the changes and dispose of the transaction
acTrans.Commit();
VBA/ActiveX 代码参考Sub OverrideDimensionText()
Dim dimObj As AcadDimAligned
Dim point1(0 To 2) As Double
Dim point2(0 To 2) As Double
' Define the dimension
point1(0) = 5#: point1(1) = 3#: point1(2) = 0#
point2(0) = 10#: point2(1) = 3#: point2(2) = 0#
location(0) = 7.5: location(1) = 5#: location(2) = 0#
Set dimObj = ThisDrawing.ModelSpace. _
AddDimAligned(point1, point2, location)
' Change the text string for the dimension
dimObj.TextOverride = "The value is <>"
dimObj.Update
相关概念父主题: |
GMT+8, 2026-11-26 12:45
