设置倾斜角度 (.NET)
2024-5-18 18:36| 发布者: admin| 查看: 759| 评论: 0|原作者: admin|来自: AutoCAD
设置倾斜角度 (.NET)
倾斜角度决定了文本的向前或向后倾斜。角度表示与其垂直轴(90 度)的偏移。若要设置倾斜角度,请使用该属性更改文本样式或文本对象的属性。倾斜角必须以弧度为单位提供。正角表示向右倾斜,负值将添加到其上以将其转换为正等价物。ObliquingAngleOblique2*PI
创建倾斜文本
本示例创建一个单行文本对象,然后将其倾斜 45 度。
VB.NET
<CommandMethod("ObliqueText")> _
Public Sub ObliqueText()
    '' Start a transaction
        Dim acBlkTbl As BlockTable
                                     OpenMode.ForRead)
                                        OpenMode.ForWrite)
        '' Create a single-line text object
        Using acText As DBText = New DBText()
            acText.Position = New Point3d(3, 3, 0)
            acText.Height = 0.5
            acText.TextString = "Hello, World."
            '' Change the oblique angle of the text object to 45 degrees(0.707 in radians)
            acText.Oblique = 0.707
            acBlkTblRec.AppendEntity(acText)
            acTrans.AddNewlyCreatedDBObject(acText, True)
        End Using
        '' Save the changes and dispose of the transaction
        acTrans.Commit()
    End Using
C#
[CommandMethod("ObliqueText")]
public static void ObliqueText()
    // Start a transaction
        BlockTable acBlkTbl;
        BlockTableRecord acBlkTblRec;
        // Create a single-line text object
        using (DBText acText = new DBText())
            acText.Position = new Point3d(3, 3, 0);
            acText.Height = 0.5;
            acText.TextString = "Hello, World.";
            // Change the oblique angle of the text object to 45 degrees(0.707 in radians)
            acText.Oblique = 0.707;
            acBlkTblRec.AppendEntity(acText);
            acTrans.AddNewlyCreatedDBObject(acText, true);
        // Save the changes and dispose of the transaction
        acTrans.Commit();
VBA/ActiveX 代码参考
Sub ObliqueText()
    Dim textObj As AcadText
    Dim textString As String
    Dim height As Double
    ' Define the text object
    textString = "Hello, World."
    insertionPoint(0) = 3
    insertionPoint(1) = 3
    insertionPoint(2) = 0
    height = 0.5
    ' Create the text object in model space
    Set textObj = ThisDrawing.ModelSpace. _
                      AddText(textString, insertionPoint, height)
    ' Change the value of the ObliqueAngle
    ' to 45 degrees (.707 radians)
    textObj.ObliqueAngle = 0.707
    textObj.Update
GMT+8, 2026-11-30 10:52
