了解 AutoCAD 如何保存图层状态 (.NET)
AutoCAD 将图层设置信息保存在对象的扩展字典中。首次保存图层状态时,AutoCAD 将执行以下操作:LayerTable
每次在图形中保存另一个图层设置时,AutoCAD 都会创建另一个对象来描述所保存的设置,并将其存储在 ACAD_LAYERSTATE 字典中。下图说明了该过程。XRecordXRecord ![]() 在处理图层状态时,您不需要(也不应尝试)直接操作条目。使用对象的函数访问字典。一旦您引用了字典,您就可以单步执行表示为对象的每个条目。LayerStateManagerDBDictionaryEntry 列出图形中保存的图层状态如果已在当前图形中保存了图层状态,则以下代码将列出所有已保存的图层状态的名称: VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("ListLayerStates")> _
Public Sub ListLayerStates()
'' Start a transaction
Dim acLyrStMan As LayerStateManager
acLyrStMan = acCurDb.LayerStateManager
Dim acDbDict As DBDictionary
acDbDict = acTrans.GetObject(acLyrStMan.LayerStatesDictionaryId(True), _
OpenMode.ForRead)
Dim sLayerStateNames As String = ""
For Each acDbDictEnt As DBDictionaryEntry In acDbDict
sLayerStateNames = sLayerStateNames & vbLf & acDbDictEnt.Key
Next
Application.ShowAlertDialog("The saved layer settings in this drawing are:" & _
sLayerStateNames)
'' Dispose of the transaction
End Using
[CommandMethod("ListLayerStates")]
public static void ListLayerStates()
// Start a transaction
LayerStateManager acLyrStMan;
acLyrStMan = acCurDb.LayerStateManager;
DBDictionary acDbDict;
acDbDict = acTrans.GetObject(acLyrStMan.LayerStatesDictionaryId(true),
OpenMode.ForRead) as DBDictionary;
string sLayerStateNames = "";
foreach (DBDictionaryEntry acDbDictEnt in acDbDict)
sLayerStateNames = sLayerStateNames + "\n" + acDbDictEnt.Key;
Application.ShowAlertDialog("The saved layer settings in this drawing are:" +
sLayerStateNames);
// Dispose of the transaction
VBA/ActiveX 代码参考Sub ListLayerStates()
On Error Resume Next
Dim oLSMDict As AcadDictionary
Dim XRec As Object
Dim layerstateNames As String
layerstateNames = ""
' Get the ACAD_LAYERSTATES dictionary, which is in the
' extension dictionary in the Layers object.
Set oLSMDict = ThisDrawing.Layers. _
GetExtensionDictionary.Item("ACAD_LAYERSTATES")
' List the name of each saved layer setting. Settings are
' stored as XRecords in the dictionary.
For Each XRec In oLSMDict
layerstateNames = layerstateNames + XRec.Name + vbCrLf
Next XRec
MsgBox "The saved layer settings in this drawing are: " + _
vbCrLf + layerstateNames
相关概念父主题: |
GMT+8, 2026-10-28 17:40
