为对象分配线型 (.NET)
2024-5-18 18:36| 发布者: admin| 查看: 725| 评论: 0|原作者: admin|来自: AutoCAD
为对象分配线型 (.NET)
以下示例创建一个圆圈,并为其分配“中心”线型。
VB.NET
<CommandMethod("SetObjectLinetype")> _
Public Sub SetObjectLinetype()
    '' Start a transaction
        '' Open the Linetype table for read
        Dim acLineTypTbl As LinetypeTable
        acLineTypTbl = acTrans.GetObject(acCurDb.LinetypeTableId, _
                                         OpenMode.ForRead)
        Dim sLineTypName As String = "Center"
        If acLineTypTbl.Has(sLineTypName) = False Then
            acCurDb.LoadLineTypeFile(sLineTypName, "acad.lin")
        End If
        Dim acBlkTbl As BlockTable
                                     OpenMode.ForRead)
                                        OpenMode.ForWrite)
        '' Create a circle object
        Using acCirc As Circle = New Circle()
            acCirc.Center = New Point3d(2, 2, 0)
            acCirc.Radius = 1
            acCirc.Linetype = sLineTypName
            acBlkTblRec.AppendEntity(acCirc)
            acTrans.AddNewlyCreatedDBObject(acCirc, True)
        End Using
        '' Save the changes and dispose of the transaction
        acTrans.Commit()
    End Using
C#
[CommandMethod("SetObjectLinetype")]
public static void SetObjectLinetype()
    // Start a transaction
        // Open the Linetype table for read
        LinetypeTable acLineTypTbl;
                                            OpenMode.ForRead) as LinetypeTable;
        string sLineTypName = "Center";
        if (acLineTypTbl.Has(sLineTypName) == false)
            acCurDb.LoadLineTypeFile(sLineTypName, "acad.lin");
        BlockTable acBlkTbl;
        BlockTableRecord acBlkTblRec;
        // Create a circle object
        using (Circle acCirc = new Circle())
            acCirc.Center = new Point3d(2, 2, 0);
            acCirc.Radius = 1;
            acCirc.Linetype = sLineTypName;
            acBlkTblRec.AppendEntity(acCirc);
            acTrans.AddNewlyCreatedDBObject(acCirc, true);
        // Save the changes and dispose of the transaction
        acTrans.Commit();
VBA/ActiveX 代码参考
    ' Load the Center linetype
    Dim linetypeName As String
    linetypeName = "Center"
    On Error Resume Next
    ThisDrawing.Linetypes.Load linetypeName, "acad.lin"
    ' Define the center point of the circle
    Dim centerPt(0 To 2) As Double
    centerPt(0) = 0: centerPt(1) = 3: centerPt(2) = 0
    ' Create a new circle and assign it the ACI value of 4
    Dim circleObj As AcadCircle
    Set circleObj = ThisDrawing.ModelSpace.AddCircle(centerPt, 1)
    circleObj.Linetype = linetypeName
    circleObj.Update
GMT+8, 2026-10-27 19:52
