使颜色流通过数据库 (.NET)
本示例使用属性设置通过对象的颜色电流。DatabaseCecolor VB.NETImports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.Colors
<CommandMethod("SetColorCurrent")> _
Public Sub SetColorCurrent()
'' Get the current document
'' Set the current color
acDoc.Database.Cecolor = Color.FromColorIndex(ColorMethod.ByLayer, 256)
using Autodesk.AutoCAD.Colors;
[CommandMethod("SetColorCurrent")]
public static void SetColorCurrent()
// Get the current document
// Set the current color
acDoc.Database.Cecolor = Color.FromColorIndex(ColorMethod.ByLayer, 256);
相关概念父主题: |
GMT+8, 2026-11-29 14:14
