编辑填充边界 (.NET)
2024-5-18 18:36| 发布者: admin| 查看: 959| 评论: 0|原作者: admin|来自: AutoCAD
编辑填充边界 (.NET)
您可以在对象的边界上追加、插入或删除循环。关联填充将更新以匹配对其边界所做的任何更改。非关联填充线不会更新。Hatch
若要编辑填充边界,请使用下列方法之一:
AppendLoop
在填充物上附加一个环。定义附加了方法的第一个参数和枚举定义的常量的循环类型。AppendLoopHatchLoopTypes
GetLoopAt
获取填充的给定索引处的循环。
InsertLoopAt
在填充的给定索引处插入一个环。
删除循环在
删除填充的给定索引处的循环。
若要查询填充边界,请使用下列方法之一:
LoopTypeAt
获取填充的给定索引处的循环类型。
循环数
获取填充的循环数。
将内环追加到填充物
本示例创建一个关联填充。然后,它创建一个圆圈,并将该圆圈作为内环附加到舱口。
VB.NET
<CommandMethod("EditHatchAppendLoop")> _
Public Sub EditHatchAppendLoop()
    '' Start a transaction
        Dim acBlkTbl As BlockTable
                                     OpenMode.ForRead)
                                        OpenMode.ForWrite)
        '' Create an arc object for the closed boundary to hatch
        Using acArc As Arc = New Arc(New Point3d(5, 3, 0), 3, 0, 3.141592)
            acBlkTblRec.AppendEntity(acArc)
            acTrans.AddNewlyCreatedDBObject(acArc, True)
            '' Create an line object for the closed boundary to hatch
            Using acLine As Line = New Line(acArc.StartPoint, acArc.EndPoint)
                acBlkTblRec.AppendEntity(acLine)
                acTrans.AddNewlyCreatedDBObject(acLine, True)
                '' Adds the arc and line to an object id collection
                Dim acObjIdColl As ObjectIdCollection = New ObjectIdCollection()
                acObjIdColl.Add(acArc.ObjectId)
                acObjIdColl.Add(acLine.ObjectId)
                '' Create the hatch object and append it to the block table record
                Using acHatch As Hatch = New Hatch()
                    acBlkTblRec.AppendEntity(acHatch)
                    acTrans.AddNewlyCreatedDBObject(acHatch, True)
                    '' Set the properties of the hatch object
                    '' Associative must be set after the hatch object is appended to the
                    '' block table record and before AppendLoop
                    acHatch.SetHatchPattern(HatchPatternType.PreDefined, "ANSI31")
                    acHatch.Associative = True
                    acHatch.AppendLoop(HatchLoopTypes.Outermost, acObjIdColl)
                    '' Create a circle object for the inner boundary of the hatch
                    Using acCirc As Circle = New Circle()
                        acCirc.Center = New Point3d(5, 4.5, 0)
                        acCirc.Radius = 1
                        acBlkTblRec.AppendEntity(acCirc)
                        acTrans.AddNewlyCreatedDBObject(acCirc, True)
                        '' Adds the circle to an object id collection
                        acObjIdColl.Clear()
                        acObjIdColl.Add(acCirc.ObjectId)
                        '' Append the circle as the inner loop of the hatch and evaluate it
                        acHatch.AppendLoop(HatchLoopTypes.Default, acObjIdColl)
                        acHatch.EvaluateHatch(True)
                    End Using
                End Using
            End Using
        End Using
        '' Save the new object to the database
        acTrans.Commit()
    End Using
C#
[CommandMethod("EditHatchAppendLoop")]
public static void EditHatchAppendLoop()
    // Start a transaction
        BlockTable acBlkTbl;
        BlockTableRecord acBlkTblRec;
        // Create an arc object for the closed boundary to hatch
        using (Arc acArc = new Arc(new Point3d(5, 3, 0), 3, 0, 3.141592))
            acBlkTblRec.AppendEntity(acArc);
            acTrans.AddNewlyCreatedDBObject(acArc, true);
            // Create an line object for the closed boundary to hatch
            using (Line acLine = new Line(acArc.StartPoint, acArc.EndPoint))
                acBlkTblRec.AppendEntity(acLine);
                acTrans.AddNewlyCreatedDBObject(acLine, true);
                // Adds the arc and line to an object id collection
                ObjectIdCollection acObjIdColl = new ObjectIdCollection();
                acObjIdColl.Add(acArc.ObjectId);
                acObjIdColl.Add(acLine.ObjectId);
                // Create the hatch object and append it to the block table record
                using (Hatch acHatch = new Hatch())
                    acBlkTblRec.AppendEntity(acHatch);
                    acTrans.AddNewlyCreatedDBObject(acHatch, true);
                    // Set the properties of the hatch object
                    // Associative must be set after the hatch object is appended to the
                    // block table record and before AppendLoop
                    acHatch.SetHatchPattern(HatchPatternType.PreDefined, "ANSI31");
                    acHatch.Associative = true;
                    acHatch.AppendLoop(HatchLoopTypes.Outermost, acObjIdColl);
                    // Create a circle object for the inner boundary of the hatch
                    using (Circle acCirc = new Circle())
                        acCirc.Center = new Point3d(5, 4.5, 0);
                        acCirc.Radius = 1;
                        acBlkTblRec.AppendEntity(acCirc);
                        acTrans.AddNewlyCreatedDBObject(acCirc, true);
                        // Adds the circle to an object id collection
                        acObjIdColl.Clear();
                        acObjIdColl.Add(acCirc.ObjectId);
                        // Append the circle as the inner loop of the hatch and evaluate it
                        acHatch.AppendLoop(HatchLoopTypes.Default, acObjIdColl);
                        acHatch.EvaluateHatch(true);
        // Save the new object to the database
        acTrans.Commit();
VBA/ActiveX 代码参考
    Dim hatchObj As AcadHatch
    Dim patternName As String
    Dim PatternType As Long
    Dim bAssociativity As Boolean
    ' Define and create the hatch
    patternName = "ANSI31"
    PatternType = 0
    bAssociativity = True
    Set hatchObj = ThisDrawing.ModelSpace. _
                       AddHatch(PatternType, patternName, bAssociativity)
    ' Create the outer loop for the hatch.
    Dim outerLoop(0 To 1) As AcadEntity
    Dim center(0 To 2) As Double
    Dim radius As Double
    Dim startAngle As Double
    Dim endAngle As Double
    center(0) = 5: center(1) = 3: center(2) = 0
    radius = 3
    startAngle = 0
    endAngle = 3.141592
    Set outerLoop(0) = ThisDrawing.ModelSpace. _
                           AddArc(center, radius, startAngle, endAngle)
    Set outerLoop(1) = ThisDrawing.ModelSpace. _
                           AddLine(outerLoop(0).startPoint, outerLoop(0).endPoint)
    ' Append the outer loop to the hatch object
    hatchObj.AppendOuterLoop (outerLoop)
    ' Create a circle as the inner loop for the hatch.
    Dim innerLoop(0) As AcadEntity
    center(0) = 5: center(1) = 4.5: center(2) = 0
    radius = 1
    Set innerLoop(0) = ThisDrawing.ModelSpace. _
                           AddCircle(center, radius)
    ' Append the circle as an inner loop to the hatch
    hatchObj.AppendInnerLoop (innerLoop)
    ' Evaluate and display the hatch
    hatchObj.Evaluate
    ThisDrawing.Regen True
GMT+8, 2026-10-30 22:49
