编辑样条曲线 (.NET)
您可以编辑开放样条或闭样条的属性,甚至可以将其转换为折线。使用以下属性可以打开或关闭样条曲线、更改其控制点或反转样条曲线的方向:
此外,还可以使用以下方法编辑样条曲线:
使用以下只读属性查询样条曲线:
更改样条上的控制点本示例创建一个样条曲线,然后更改样条曲线的第一个控制点。 VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("EditSpline")> _
Public Sub EditSpline()
'' Start a transaction
Dim acBlkTbl As BlockTable
OpenMode.ForRead)
OpenMode.ForWrite)
'' Create a Point3d Collection
Dim acPt3dColl As Point3dCollection = New Point3dCollection()
acPt3dColl.Add(New Point3d(1, 1, 0))
acPt3dColl.Add(New Point3d(5, 5, 0))
acPt3dColl.Add(New Point3d(10, 0, 0))
'' Set the start and end tangency
Dim acStartTan As Vector3d = New Vector3d(0.5, 0.5, 0)
Dim acEndTan As Vector3d = New Vector3d(0.5, 0.5, 0)
'' Create a spline
Using acSpline As Spline = New Spline(acPt3dColl, _
acStartTan, _
acEndTan, 4, 0)
'' Set a control point
acSpline.SetControlPointAt(0, New Point3d(0, 3, 0))
acBlkTblRec.AppendEntity(acSpline)
acTrans.AddNewlyCreatedDBObject(acSpline, True)
End Using
'' Save the new objects to the database
acTrans.Commit()
End Using
[CommandMethod("EditSpline")]
public static void EditSpline()
// Start a transaction
BlockTable acBlkTbl;
BlockTableRecord acBlkTblRec;
// Create a Point3d Collection
Point3dCollection acPt3dColl = new Point3dCollection();
acPt3dColl.Add(new Point3d(1, 1, 0));
acPt3dColl.Add(new Point3d(5, 5, 0));
acPt3dColl.Add(new Point3d(10, 0, 0));
// Set the start and end tangency
Vector3d acStartTan = new Vector3d(0.5, 0.5, 0);
Vector3d acEndTan = new Vector3d(0.5, 0.5, 0);
// Create a spline
using (Spline acSpline = new Spline(acPt3dColl,
acStartTan,
acEndTan, 4, 0))
// Set a control point
acSpline.SetControlPointAt(0, new Point3d(0, 3, 0));
acBlkTblRec.AppendEntity(acSpline);
acTrans.AddNewlyCreatedDBObject(acSpline, true);
// Save the new objects to the database
acTrans.Commit();
VBA/ActiveX 代码参考Sub EditSpline()
' Create the spline
Dim splineObj As AcadSpline
Dim startTan(0 To 2) As Double
Dim endTan(0 To 2) As Double
Dim fitPoints(0 To 8) As Double
startTan(0) = 0.5: startTan(1) = 0.5: startTan(2) = 0
endTan(0) = 0.5: endTan(1) = 0.5: endTan(2) = 0
fitPoints(0) = 1: fitPoints(1) = 1: fitPoints(2) = 0
fitPoints(3) = 5: fitPoints(4) = 5: fitPoints(5) = 0
fitPoints(6) = 10: fitPoints(7) = 0: fitPoints(8) = 0
Set splineObj = ThisDrawing.ModelSpace. _
AddSpline(fitPoints, startTan, endTan)
splineObj.Update
' Change the coordinate of the first fit point
Dim controlPoint(0 To 2) As Double
controlPoint(0) = 0
controlPoint(1) = 3
controlPoint(2) = 0
splineObj.SetControlPoint 0, controlPoint
splineObj.Update
父主题: |
GMT+8, 2026-11-29 11:09
