分解对象 (.NET)
分解对象会将单个对象转换为其组成部分。您可以使用该函数分解对象,并且它需要一个对象,其中用于返回生成的对象。例如,分解折线可能会导致创建包含多条直线和圆弧的对象集合。ExplodeDBObjectCollection 如果块被分解,则返回的对象集合将保存定义块的图形对象。物体爆炸后,原始物体保持不变。如果希望返回的对象替换原始对象,则必须擦除原始对象,然后必须将返回的对象添加到块表记录中。 分解折线本示例创建一个轻量级折线对象,然后将折线分解为最简单的对象。折线分解后,将对其进行处理,并将返回的对象添加到模型空间中。 VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("ExplodeObject")> _
Public Sub ExplodeObject()
'' Start a transaction
Dim acBlkTbl As BlockTable
OpenMode.ForRead)
OpenMode.ForWrite)
'' Create a lightweight polyline
Using acPoly As Polyline = New Polyline()
acPoly.AddVertexAt(0, New Point2d(1, 1), 0, 0, 0)
acPoly.AddVertexAt(1, New Point2d(1, 2), 0, 0, 0)
acPoly.AddVertexAt(2, New Point2d(2, 2), 0, 0, 0)
acPoly.AddVertexAt(3, New Point2d(3, 2), 0, 0, 0)
acPoly.AddVertexAt(4, New Point2d(4, 4), 0, 0, 0)
acPoly.AddVertexAt(5, New Point2d(4, 1), 0, 0, 0)
'' Sets the bulge at index 3
acPoly.SetBulgeAt(3, -0.5)
'' Explodes the polyline
Dim acDBObjColl As DBObjectCollection = New DBObjectCollection()
acPoly.Explode(acDBObjColl)
For Each acEnt As Entity In acDBObjColl
acBlkTblRec.AppendEntity(acEnt)
acTrans.AddNewlyCreatedDBObject(acEnt, True)
Next
'' Dispose of the in memory polyline
End Using
'' Save the new objects to the database
acTrans.Commit()
End Using
[CommandMethod("ExplodeObject")]
public static void ExplodeObject()
// Start a transaction
BlockTable acBlkTbl;
BlockTableRecord acBlkTblRec;
// Create a lightweight polyline
using (Polyline acPoly = new Polyline())
acPoly.AddVertexAt(0, new Point2d(1, 1), 0, 0, 0);
acPoly.AddVertexAt(1, new Point2d(1, 2), 0, 0, 0);
acPoly.AddVertexAt(2, new Point2d(2, 2), 0, 0, 0);
acPoly.AddVertexAt(3, new Point2d(3, 2), 0, 0, 0);
acPoly.AddVertexAt(4, new Point2d(4, 4), 0, 0, 0);
acPoly.AddVertexAt(5, new Point2d(4, 1), 0, 0, 0);
// Sets the bulge at index 3
acPoly.SetBulgeAt(3, -0.5);
// Explodes the polyline
DBObjectCollection acDBObjColl = new DBObjectCollection();
acPoly.Explode(acDBObjColl);
foreach (Entity acEnt in acDBObjColl)
acBlkTblRec.AppendEntity(acEnt);
acTrans.AddNewlyCreatedDBObject(acEnt, true);
// Dispose of the in memory polyline
// Save the new objects to the database
acTrans.Commit();
VBA/ActiveX 代码参考Sub ExplodeObject()
Dim points(0 To 11) As Double
' Define the 2D polyline points
points(0) = 1: points(1) = 1
points(2) = 1: points(3) = 2
points(4) = 2: points(5) = 2
points(6) = 3: points(7) = 2
points(8) = 4: points(9) = 4
points(10) = 4: points(11) = 1
' Create a light weight Polyline object
Set plineObj = ThisDrawing.ModelSpace. _
AddLightWeightPolyline(points)
' Set the bulge on one segment to vary the
' type of objects in the polyline
plineObj.SetBulge 3, -0.5
' Explode the polyline
Dim explodedObjects As Variant
explodedObjects = plineObj.Explode
' Erase the polyline
plineObj.Erase
相关概念父主题: |
GMT+8, 2026-10-17 13:24
