扩展和修剪对象 (.NET)
您可以更改圆弧的角度,也可以更改直线、开放折线、椭圆弧和开放样条的长度。结果类似于延伸和修剪对象。 您可以通过编辑对象的属性来扩展或修剪对象。例如,要延长一条线,只需更改 or 属性的坐标即可。若要更改圆弧的角度,请更改圆弧的 or 属性。更改对象的一个或多个属性后,可能需要重新生成显示才能在绘图窗口中查看更改。StartPointEndPointStartAngleEndAngle 加长一条线此示例创建一条线,然后更改该线的终结点,从而生成更长的线。 VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("ExtendObject")> _
Public Sub ExtendObject()
'' Start a transaction
Dim acBlkTbl As BlockTable
OpenMode.ForRead)
OpenMode.ForWrite)
'' Create a line that starts at (4,4,0) and ends at (7,7,0)
Using acLine As Line = New Line(New Point3d(4, 4, 0), _
New Point3d(7, 7, 0))
acBlkTblRec.AppendEntity(acLine)
acTrans.AddNewlyCreatedDBObject(acLine, True)
'' Update the display and diaplay a message box
acDoc.Editor.Regen()
Application.ShowAlertDialog("Before extend")
'' Double the length of the line
acLine.EndPoint = acLine.EndPoint + acLine.Delta
End Using
'' Save the new object to the database
acTrans.Commit()
End Using
[CommandMethod("ExtendObject")]
public static void ExtendObject()
// Start a transaction
BlockTable acBlkTbl;
BlockTableRecord acBlkTblRec;
// Create a line that starts at (4,4,0) and ends at (7,7,0)
using (Line acLine = new Line(new Point3d(4, 4, 0),
new Point3d(7, 7, 0)))
acBlkTblRec.AppendEntity(acLine);
acTrans.AddNewlyCreatedDBObject(acLine, true);
// Update the display and diaplay a message box
acDoc.Editor.Regen();
Application.ShowAlertDialog("Before extend");
// Double the length of the line
acLine.EndPoint = acLine.EndPoint + acLine.Delta;
// Save the new object to the database
acTrans.Commit();
VBA/ActiveX 代码参考Sub ExtendObject()
' Define and create the line
Dim lineObj As AcadLine
startPoint(0) = 4
startPoint(1) = 4
startPoint(2) = 0
endPoint(0) = 7
endPoint(1) = 7
endPoint(2) = 0
Set lineObj = ThisDrawing.ModelSpace. _
AddLine(startPoint, endPoint)
lineObj.Update
endPoint(0) = lineObj.endPoint(0) + lineObj.Delta(0)
endPoint(1) = lineObj.endPoint(1) + lineObj.Delta(1)
endPoint(2) = lineObj.endPoint(2) + lineObj.Delta(2)
lineObj.endPoint = endPoint
lineObj.Update
相关概念父主题: |
GMT+8, 2026-10-17 22:54
