擦除对象 (.NET)
2024-5-18 18:36| 发布者: admin| 查看: 753| 评论: 0|原作者: admin|来自: AutoCAD
擦除对象 (.NET)
您可以使用该方法删除非图形和图形对象。Erase
谨慎:虽然许多非图形对象(如图层表和模型空间块表记录)具有方法,但不应调用该方法。如果在其中一个对象上调用,则会发生错误。EraseErase
创建和擦除折线
本示例创建轻量级折线,然后擦除它。
VB.NET
<CommandMethod("EraseObject")> _
Public Sub EraseObject()
    '' Start a transaction
        Dim acBlkTbl As BlockTable
        acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
                                        OpenMode.ForWrite)
        '' Create a lightweight polyline
        Using acPoly As Polyline = New Polyline()
            acPoly.AddVertexAt(0, New Point2d(2, 4), 0, 0, 0)
            acPoly.AddVertexAt(1, New Point2d(4, 2), 0, 0, 0)
            acPoly.AddVertexAt(2, New Point2d(6, 4), 0, 0, 0)
            acBlkTblRec.AppendEntity(acPoly)
            acTrans.AddNewlyCreatedDBObject(acPoly, True)
            '' Update the display and display an alert message
            acDoc.Editor.Regen()
            Application.ShowAlertDialog("Erase the newly added polyline.")
            '' Erase the polyline from the drawing
            acPoly.Erase(True)
        End Using
        '' Save the new object to the database
        acTrans.Commit()
    End Using
C#
[CommandMethod("EraseObject")]
public static void EraseObject()
    // Start a transaction
        BlockTable acBlkTbl;
        BlockTableRecord acBlkTblRec;
        // Create a lightweight polyline
        using (Polyline acPoly = new Polyline())
            acPoly.AddVertexAt(0, new Point2d(2, 4), 0, 0, 0);
            acPoly.AddVertexAt(1, new Point2d(4, 2), 0, 0, 0);
            acPoly.AddVertexAt(2, new Point2d(6, 4), 0, 0, 0);
            acBlkTblRec.AppendEntity(acPoly);
            acTrans.AddNewlyCreatedDBObject(acPoly, true);
            // Update the display and display an alert message
            acDoc.Editor.Regen();
            Application.ShowAlertDialog("Erase the newly added polyline.");
            // Erase the polyline from the drawing
            acPoly.Erase(true);
        // Save the new object to the database
        acTrans.Commit();
VBA/ActiveX 代码参考
Sub EraseObject()
    ' Create the polyline
    Dim lwpolyObj As AcadLWPolyline
    Dim vertices(0 To 5) As Double
    vertices(0) = 2: vertices(1) = 4
    vertices(2) = 4: vertices(3) = 2
    vertices(4) = 6: vertices(5) = 4
    Set lwpolyObj = ThisDrawing.ModelSpace. _
                                     AddLightWeightPolyline(vertices)
    ZoomAll
    lwpolyObj.Delete
    ThisDrawing.Regen acActiveViewport
GMT+8, 2026-11-30 12:10
