扩展数据筛选器 (.NET)
2024-5-18 18:36| 发布者: admin| 查看: 756| 评论: 0|原作者: admin|来自: AutoCAD
扩展数据筛选器 (.NET)
外部应用程序可以将文本字符串、数值、三维点、距离和图层名称等数据附着到 AutoCAD 对象。此数据称为扩展数据或 xdata。您可以筛选包含指定应用程序的扩展数据的实体。
选择包含 xdata 的圆圈
以下示例筛选包含“MY_APP”应用程序添加的 xdata 的圆圈:
VB.NET
Imports Autodesk.AutoCAD.EditorInput
<CommandMethod("FilterXdata")> _
Public Sub FilterXdata()
    '' Get the current document editor
    Dim acDocEd As Editor = Application.DocumentManager.MdiActiveDocument.Editor
    '' Create a TypedValue array to define the filter criteria
    Dim acTypValAr(1) As TypedValue
    acTypValAr.SetValue(New TypedValue(DxfCode.Start, "Circle"), 0)
    acTypValAr.SetValue(New TypedValue(DxfCode.ExtendedDataRegAppName, _
                                       "MY_APP"), 1)
    '' Assign the filter criteria to a SelectionFilter object
    Dim acSelFtr As SelectionFilter = New SelectionFilter(acTypValAr)
    '' Request for objects to be selected in the drawing area
    Dim acSSPrompt As PromptSelectionResult
    acSSPrompt = acDocEd.GetSelection(acSelFtr)
    '' If the prompt status is OK, objects were selected
    If acSSPrompt.Status = PromptStatus.OK Then
        Dim acSSet As SelectionSet = acSSPrompt.Value
        Application.ShowAlertDialog("Number of objects selected: " & _
                                    acSSet.Count.ToString())
    Else
        Application.ShowAlertDialog("Number of objects selected: 0")
    End If
C#
using Autodesk.AutoCAD.EditorInput;
[CommandMethod("FilterXdata")]
public static void FilterXdata()
    // Get the current document editor
    Editor acDocEd = Application.DocumentManager.MdiActiveDocument.Editor;
    // Create a TypedValue array to define the filter criteria
    TypedValue[] acTypValAr = new TypedValue[2];
    acTypValAr.SetValue(new TypedValue((int)DxfCode.Start, "Circle"), 0);
    acTypValAr.SetValue(new TypedValue((int)DxfCode.ExtendedDataRegAppName,
                                        "MY_APP"), 1);
    // Assign the filter criteria to a SelectionFilter object
    SelectionFilter acSelFtr = new SelectionFilter(acTypValAr);
    // Request for objects to be selected in the drawing area
    PromptSelectionResult acSSPrompt;
    acSSPrompt = acDocEd.GetSelection(acSelFtr);
    // If the prompt status is OK, objects were selected
    if (acSSPrompt.Status == PromptStatus.OK)
        SelectionSet acSSet = acSSPrompt.Value;
        Application.ShowAlertDialog("Number of objects selected: " +
                                    acSSet.Count.ToString());
    else
        Application.ShowAlertDialog("Number of objects selected: 0");
VBA/ActiveX 代码参考
Sub FilterXdata()
    Dim sset As AcadSelectionSet
    Dim FilterType(1) As Integer
    Dim FilterData(1) As Variant
    Set sset = ThisDrawing.SelectionSets.Add("SS1")
    FilterType(0) = 0: FilterData(0) = "Circle"
    FilterType(1) = 1001: FilterData(1) = "MY_APP"
    sset.SelectOnScreen FilterType, FilterData
    MsgBox "Number of objects selected: " & sset.Count
    ' Remove the selection set at the end
    sset.Delete
GMT+8, 2026-10-24 09:36
