创建和打开图形 (.NET)
若要创建新图形或打开现有图形,请使用对象的方法。该方法基于图形样板创建新的图形文件,并将该图形添加到 .该方法将打开现有图形文件。DocumentCollectionExtensionAddDocumentCollectionExtensionOpen 创建新图形本示例使用该方法基于 acad.dwt 图形样板文件创建新图形。Add VB.NETImports Autodesk.AutoCAD.ApplicationServices
<CommandMethod("NewDrawing", CommandFlags.Session)> _
Public Sub NewDrawing()
'' Specify the template to use, if the template is not found
'' the default settings are used.
Dim strTemplatePath As String = "acad.dwt"
Dim acDocMgr As DocumentCollection = Application.DocumentManager
Dim acDoc As Document = DocumentCollectionExtension.Add(acDocMgr, strTemplatePath)
acDocMgr.MdiActiveDocument = acDoc
C#using Autodesk.AutoCAD.ApplicationServices;
[CommandMethod("NewDrawing", CommandFlags.Session)]
public static void NewDrawing()
// Specify the template to use, if the template is not found
// the default settings are used.
string strTemplatePath = "acad.dwt";
DocumentCollection acDocMgr = Application.DocumentManager;
Document acDoc = acDocMgr.Add(strTemplatePath);
acDocMgr.MdiActiveDocument = acDoc;
VBA/ActiveX 代码参考Sub NewDrawing()
Dim docObj As AcadDocument
Set docObj = ThisDrawing.Application.Documents.Add(strTemplatePath)
打开现有图形本示例使用该方法打开现有图形。在打开图形之前,代码会在尝试打开文件之前检查文件是否存在。Open VB.NETImports System.IO
<CommandMethod("OpenDrawing", CommandFlags.Session)> _
Public Sub OpenDrawing()
Dim strFileName As String = "C:\campus.dwg"
If (File.Exists(strFileName)) Then
DocumentCollectionExtension.Open(acDocMgr, strFileName, False)
Else
acDocMgr.MdiActiveDocument.Editor.WriteMessage("File " & strFileName & _
" does not exist.")
End If
C#using System.IO;
[CommandMethod("OpenDrawing", CommandFlags.Session)]
public static void OpenDrawing()
string strFileName = "C:\\campus.dwg";
if (File.Exists(strFileName))
acDocMgr.Open(strFileName, false);
else
acDocMgr.MdiActiveDocument.Editor.WriteMessage("File " + strFileName +
" does not exist.");
VBA/ActiveX 代码参考Sub OpenDrawing()
Dim dwgName As String
dwgName = "c:\campus.dwg"
If Dir(dwgName) <> "" Then
ThisDrawing.Application.Documents.Open dwgName
Else
MsgBox "File " & dwgName & " does not exist."
End If
相关概念父主题: |
GMT+8, 2026-10-27 11:15
