擦除集合对象的成员 (.NET)
2024-5-18 18:36| 发布者: admin| 查看: 1051| 评论: 0|原作者: admin|来自: AutoCAD
擦除集合对象的成员 (.NET)
可以使用在成员对象上找到的方法擦除集合对象中的成员。例如,以下代码从对象中删除层 MyLayer。EraseLayerTable
在从图形中擦除图层之前,应确保可以安全地将其移除。要确定是否可以擦除图层或其他命名对象(如块或文本样式),应使用该方法。Purge
VB.NET
<CommandMethod("RemoveMyLayer")> _
Public Sub RemoveMyLayer()
  '' Get the current document and database, and start a transaction
      '' Returns the layer table for the current database
      Dim acLyrTbl As LayerTable
      acLyrTbl = acTrans.GetObject(acCurDb.LayerTableId, _
                                   OpenMode.ForRead)
      '' Check to see if MyLayer exists in the Layer table
      If acLyrTbl.Has("MyLayer") = True Then
          Dim acLyrTblRec As LayerTableRecord
          acLyrTblRec = acTrans.GetObject(acLyrTbl("MyLayer"), _
                                          OpenMode.ForWrite)
          Try
              acLyrTblRec.Erase()
              acDoc.Editor.WriteMessage(vbLf & "'MyLayer' was erased")
              '' Commit the changes
              acTrans.Commit()
          Catch
              acDoc.Editor.WriteMessage(vbLf & "'MyLayer' could not be erased")
          End Try
      Else
          acDoc.Editor.WriteMessage(vbLf & "'MyLayer' does not exist")
      End If
      '' Dispose of the transaction
  End Using
C#
[CommandMethod("RemoveMyLayer")]
public static void RemoveMyLayer()
  // Get the current document and database, and start a transaction
      // Returns the layer table for the current database
      LayerTable acLyrTbl;
                                   OpenMode.ForRead) as LayerTable;
      // Check to see if MyLayer exists in the Layer table
      if (acLyrTbl.Has("MyLayer") == true)
          LayerTableRecord acLyrTblRec;
          acLyrTblRec = acTrans.GetObject(acLyrTbl["MyLayer"],
                                          OpenMode.ForWrite) as LayerTableRecord;
          try
              acLyrTblRec.Erase();
              acDoc.Editor.WriteMessage("\n'MyLayer' was erased");
              // Commit the changes
              acTrans.Commit();
          catch
              acDoc.Editor.WriteMessage("\n'MyLayer' could not be erased");
      else
          acDoc.Editor.WriteMessage("\n'MyLayer' does not exist");
      // Dispose of the transaction
VBA/ActiveX 代码参考
Sub RemoveMyLayer()
  On Error Resume Next
  '' Get the layer "MyLayer" from the Layers collection
  Dim ABCLayer As AcadLayer
  Set ABCLayer = ThisDrawing.Layers.Item("MyLayer")
  '' Check for an error, if no error occurs the layer exists
  If Err = 0 Then
    '' Delete the layer
    ABCLayer.Delete
    '' Clear the current error
    Err.Clear
    '' Get the layer again if it is found the layer could not be removed
    '' Check for error, if an error is encountered the layer was removed
    If Err <> 0 Then
      ThisDrawing.Utility.prompt "'MyLayer' was removed"
    Else
      ThisDrawing.Utility.prompt "'MyLayer' could not be removed"
    End If
  Else
    ThisDrawing.Utility.prompt "'MyLayer' does not exist"
  End If
擦除对象后,不应在程序后期再次尝试访问该对象;否则将发生错误。上面的示例在再次访问对象之前测试该对象是否存在。当发出擦除对象的请求时,应检查该方法是否存在该对象,或者使用语句捕获发生的任何异常。HasTry
GMT+8, 2026-11-29 11:05
