访问集合 (.NET)
2024-5-18 18:36| 发布者: admin| 查看: 959| 评论: 0|原作者: admin|来自: AutoCAD
访问集合 (.NET)
大多数集合和容器对象都是通过 or 对象访问的。和 对象包含一个属性,用于访问大多数可用 Collection 对象的对象或对象 ID。例如,下面的代码定义一个变量并检索表示当前图形中集合的对象:DocumentDatabaseDocumentDatabaseLayersTableLayers
VB.NET
'' Get the current document and start the Transaction Manager
Dim acCurDb As Database = Application.DocumentManager.MdiActiveDocument.Database
    '' This example returns the layer table for the current database
    Dim acLyrTbl As LayerTable
    acLyrTbl = acTrans.GetObject(acCurDb.LayerTableId, _
                                 OpenMode.ForRead)
    '' Dispose of the transaction
End Using
C#
// Get the current document and start the Transaction Manager
Database acCurDb = Application.DocumentManager.MdiActiveDocument.Database;
    // This example returns the layer table for the current database
    LayerTable acLyrTbl;
                                 OpenMode.ForRead) as LayerTable;
     // Dispose of the transaction
VBA/ActiveX 代码参考
Dim layerCollection as AcadLayers
Set layerCollection = ThisDrawing.Layers
GMT+8, 2026-10-17 10:34
