IsCanceled 方法 (ActiveX/ATO)
在收到取消传输集文件处理的请求时触发。 支持的平台:仅限 Windows 命名空间:传输塔利布 程序集: acETransmit20.tlb 签名VB.NET: Friend Class custom_class_name
Implements TransmittalProgressHandler
Public Sub isCanceled(ByRef cancelled As Integer) _
Implements ITransmittalProgressHandler.isCanceled
End Class
C#: internal class custom_class_name : TransmittalProgressHandler
public void isCanceled(out int cancelled)
返回值 (RetVal)无返回值。 言论没有其他评论。 发行信息释放:AutoCAD 2005 及更高版本 例子VB.NET: Friend Class MyProgressHandler
Implements TRANSMITTALLib.ITransmittalProgressHandler.isCanceled
Application.DocumentManager.MdiActiveDocument.Editor. _
WriteMessage(Environment.NewLine & "Transmital process cancelled status")
End Class
C#: internal class MyProgressHandler : TransmittalProgressHandler
WriteMessage(Environment.NewLine + "Transmital process cancelled status");
cancelled = 0;
相关参考 |
GMT+8, 2026-11-29 11:05
