GetDependee 方法 (ActiveX/ATO)
2024-5-18 18:36| 发布者: admin| 查看: 783| 评论: 0|原作者: admin|来自: AutoCAD
返回指定索引处的文件的依赖对象。
命名空间:传输塔利布
程序集: acETransmit20.tlb
VB.NET:
RetVal = object.getDependee(nIndex)
C#:
RetVal = object.getDependee(nIndex);
类型:TransmittalFile 对象
此方法应用到的对象。
n索引
访问:仅输入
类型:长
要检索的依赖文件的索引。
返回值 (RetVal)
指定索引处的 dependee 文件。
发行信息
释放:AutoCAD 2005 及更高版本
历史
  • 该界面已与 AutoCAD 2010 版本库中的界面合并。ITransmittalFile2ITransmittalFile
  • 该方法是在 AutoCAD 2005 版本的库中引入的。getDependeeITransmittalFile2
VB.NET:
' Custom command that displays information about a file
<CommandMethod("FileInfo")> _
Public Shared Sub FileInfo()
    ' Define file to add to the transmittal
    Dim tf As TransmittalFile = Nothing
    Dim dwgFile As String = "C:\AutoCAD\Sample\Sheet Sets\Architectural\A-01.dwg"
    ' Add file to transmittal and parse its information
    If tro.addDrawingFile(dwgFile, tf) = AddFileReturnVal.eFileAdded Then
        ' Get the current editor
        Dim acEditor As Editor = Application.DocumentManager.MdiActiveDocument.Editor
        ' Output information about the file in the transmittal set
        ' Source and full target path to the file
        acEditor.WriteMessage(Environment.NewLine & "Source Path: " & tf.sourcePath)
        acEditor.WriteMessage(Environment.NewLine & "Full Path: " & tf.fullPathForTarget)
        acEditor.WriteMessage(Environment.NewLine & "Target SubPath: " & tf.targetSubPath)
        ' See if the file is a drawing
        If System.IO.Path.GetExtension(tf.sourcePath).ToUpper() = ".DWG" Then
            ' Number of dependents and dependees
            acEditor.WriteMessage(Environment.NewLine & "# of Dependents: " & tf.numberOfDependents.ToString())
            acEditor.WriteMessage(Environment.NewLine & "# of Dependees: " & tf.numberOfDependees.ToString())
            ' Get the first dependent of the drawing
            If tf.numberOfDependents > 0 Then
                acEditor.WriteMessage(Environment.NewLine & "Name of First Dependent: " & tf.getDependent(0).sourcePath)
            Else
                acEditor.WriteMessage(Environment.NewLine & "No dependents")
            End If
            ' Get the first dependee of the drawing
            If tf.numberOfDependees > 0 Then
                acEditor.WriteMessage(Environment.NewLine & "Name of First Dependee: " & tf.getDependee(0).sourcePath)
            Else
                acEditor.WriteMessage(Environment.NewLine & "No dependees")
            End If
        End If
        ' Output file system information about the file
        acEditor.WriteMessage(Environment.NewLine & "File Exists: " & tf.fileExists.ToString())
        acEditor.WriteMessage(Environment.NewLine & "File Size: " & tf.fileSize.ToString())
        acEditor.WriteMessage(Environment.NewLine & "File Type: " & tf.FileType.ToString())
        acEditor.WriteMessage(Environment.NewLine & "Include in transmittal: " & tf.includeInTransmittal.ToString())
        acEditor.WriteMessage(Environment.NewLine & "Date/Time: " & tf.lastModifiedTime.ToLongDateString() & "  " &
        tf.lastModifiedTime.ToLongTimeString())
        acEditor.WriteMessage(Environment.NewLine & "Type: " & tf.type.ToString())
        acEditor.WriteMessage(Environment.NewLine & "Version: " & tf.version.ToString())
    End If
C#:
// Custom command that displays information about a file
[CommandMethod("FileInfo")]
public static void FileInfo()
    TransmittalInfo ti = TransInfo(tro.getTransmittalInfoInterface(),
                                   @"C:\Users\Public\TransmittalAPITest\");
    // Define file to add to the transmittal
    TransmittalFile tf = null;
    string dwgFile = @"C:\AutoCAD\Sample\Sheet Sets\Architectural\A-01.dwg";
    // Add file to transmittal and parse its information
    if (tro.addDrawingFile(dwgFile, out tf) == AddFileReturnVal.eFileAdded)
        // Get the current editor
        Editor acEditor = Application.DocumentManager.MdiActiveDocument.Editor;
        // Output information about the root file of the transmittal set
        // Source and full target path to the file
        acEditor.WriteMessage(Environment.NewLine + "Source Path: " + tf.sourcePath);
        acEditor.WriteMessage(Environment.NewLine + "Full Path: " + tf.fullPathForTarget);
        acEditor.WriteMessage(Environment.NewLine + "Target SubPath: " + tf.targetSubPath);
        // See if the root file is a drawing
        if (Path.GetExtension(tf.sourcePath).ToUpper() == ".DWG")
            // Number of dependents and dependees
            acEditor.WriteMessage(Environment.NewLine + "# of Dependents: " + tf.numberOfDependents.ToString());
            acEditor.WriteMessage(Environment.NewLine + "# of Dependees: " + tf.numberOfDependees.ToString());
            // Get the first dependent of the drawing
            if(tf.numberOfDependents > 0)
                acEditor.WriteMessage(Environment.NewLine + "Name of First Dependent: " + tf.getDependent(0).sourcePath);
            } else {
                acEditor.WriteMessage(Environment.NewLine + "No dependents");
            // Get the first dependee of the drawing
            if (tf.numberOfDependees > 0)
                acEditor.WriteMessage(Environment.NewLine + "Name of First Dependee: " + tf.getDependee(0).sourcePath);
            else
                acEditor.WriteMessage(Environment.NewLine + "No dependees");
        // Output file system information about the root file
        acEditor.WriteMessage(Environment.NewLine + "File Exists: " + tf.fileExists.ToString());
        acEditor.WriteMessage(Environment.NewLine + "File Size: " + tf.fileSize.ToString());
        acEditor.WriteMessage(Environment.NewLine + "File Type: " + tf.FileType.ToString());
        acEditor.WriteMessage(Environment.NewLine + "Include in transmittal: " + tf.includeInTransmittal.ToString());
        acEditor.WriteMessage(Environment.NewLine + "Date/Time: " + tf.lastModifiedTime.ToLongDateString() + "  " +
        tf.lastModifiedTime.ToLongTimeString());
        acEditor.WriteMessage(Environment.NewLine + "Type: " + tf.type.ToString());
        acEditor.WriteMessage(Environment.NewLine + "Version: " + tf.version.ToString());
GMT+8, 2026-10-18 02:03
