EndFilesGraphCreation 方法 (ActiveX/ATO)
2024-5-18 18:36| 发布者: admin| 查看: 639| 评论: 0|原作者: admin|来自: AutoCAD
在将新节点添加到传递集的文件图时触发。
命名空间:传输塔利布
程序集: acETransmit20.tlb
VB.NET:
Friend Class custom_class_name
    Implements TransmittalAddFileNotificationHandler
    Public Sub endFilesGraphCreation(pTransmit As TRANSMITTALLib.TransmittalOperation) _
        Implements TRANSMITTALLib.ITransmittalAddFileNotificationHandler.endFilesGraphCreation
End Class
C#:
internal class custom_class_name : TransmittalAddFileNotificationHandler
    public void endFilesGraphCreation(TRANSMITTALLib.TransmittalOperation pTransmit)
custom_class_name
自定义类的名称。
p传输
访问:仅输入
类型:TransmittalOperation 对象
指向表示已将新节点添加到其文件图的传递集的对象的指针。TransmittalOperation
返回值 (RetVal)
无返回值。
发行信息
释放:AutoCAD 2004 及更高版本
VB.NET:
' Custom class used to monitor files being added to the transmittal package
Friend Class MyTransFileNotifier
        Implements TRANSMITTALLib. _
        Application.DocumentManager.MdiActiveDocument.Editor. _
            WriteMessage(Environment.NewLine + "File graph creation ended.")
End Class
C#:
// Custom class used to monitor files being added to the transmittal package
internal class MyTransFileNotifier : TransmittalAddFileNotificationHandler
            WriteMessage(Environment.NewLine + "File graph creation ended.");
GMT+8, 2026-10-26 18:19
