CancelSheetSetNotification 方法 (ActiveX/ATO)
注销以前注册的工作表集回调通知处理程序。 命名空间:传输塔利布 程序集: acETransmit20.tlb 签名VB.NET: object.cancelSheetSetNotification pHandler C#: object.cancelSheetSetNotification(pHandler);
返回值 (RetVal)无返回值。 言论没有其他评论。 发行信息释放:AutoCAD 2005 及更高版本 历史
例子VB.NET: ' Notification handlers
Private Shared g_dbHandler As New MyTransDbNotifier
Private Shared g_fileHandler As New MyTransFileNotifier
Private Shared g_ssmHandler As New MyTransSSMNotifier
' Custom command that subscribes to eTransmit notifications
' Works with the transmittal API and ETRANSMIT/ARCHIVE commands
<CommandMethod("ETNotificationsStart")> _
Public Shared Sub ETNotificationsStart()
' Add the handlers
g_tro.subscribeToAddFileNotification(g_fileHandler)
g_tro.subscribeDatabaseNotification(g_dbHandler)
g_tro.subscribeSheetSetNotification(g_ssmHandler)
' Custom command that unsubscribes to eTransmit notifications
<CommandMethod("ETNotificationsEnd")> _
Public Shared Sub ETNotificationsEnd()
' Remove the handlers
g_tro.cancelSubscriptionToAddFileNotification(g_fileHandler)
g_tro.cancelDatabaseNotification(g_dbHandler)
g_tro.cancelSheetSetNotification(g_ssmHandler)
C#: // Notification handlers
private static MyTransDbNotifier g_dbHandler = new MyTransDbNotifier();
private static MyTransFileNotifier g_fileHandler = new MyTransFileNotifier();
private static MyTransSSMNotifier g_ssmHandler = new MyTransSSMNotifier();
// Custom command that subscribes to eTransmit notifications
// Works with the transmittal API and ETRANSMIT/ARCHIVE commands
[CommandMethod("ETNotificationsStart")]
public static void ETNotificationsStart()
// Add the handlers
g_tro.subscribeToAddFileNotification(g_fileHandler);
g_tro.subscribeDatabaseNotification(g_dbHandler);
g_tro.subscribeSheetSetNotification(g_ssmHandler);
// Custom command that unsubscribes to eTransmit notifications
[CommandMethod("ETNotificationsEnd")]
public static void ETNotificationsEnd()
// Remove the handlers
g_tro.cancelSubscriptionToAddFileNotification(g_fileHandler);
g_tro.cancelDatabaseNotification(g_dbHandler);
g_tro.cancelSheetSetNotification(g_ssmHandler);
相关参考 |
GMT+8, 2026-11-29 14:17
