AddFileNotificationHandler 方法 (ActiveX/ATO)
2024-5-18 18:36| 发布者: admin| 查看: 505| 评论: 0|原作者: admin|来自: AutoCAD
在将新文件添加到传递集时触发。
命名空间:传输塔利布
程序集: acETransmit20.tlb
VB.NET:
Friend Class custom_class_name
    Implements TransmittalAddFileNotificationHandler
    Public Sub addFileNotificationHandler(pFile, pTransmit) _
        Implements TRANSMITTALLib.ITransmittalAddFileNotificationHandler.addFileNotificationHandler
End Class
C#:
internal class custom_class_name : TransmittalAddFileNotificationHandler
    public void addFileNotificationHandler(pFile, pTransmit)
custom_class_name
自定义类的名称。
p文件
访问:仅输入
类型:TransmittalFile 对象
指向将图形或文件添加到传递集时创建的对象的指针。TransmittalFile
p传输
访问:仅输入
类型:TransmittalOperation 对象
指向表示要在其中添加图形或文件的传递集的对象的指针。TransmittalOperation
返回值 (RetVal)
无返回值。
发行信息
释放:AutoCAD 2004 及更高版本
VB.NET:
' Custom class used to monitor files being added to the transmittal package
Friend Class MyTransFileNotifier
    ' Used to get a notification when a drawing or file is added to the transmittal package
    Public Sub addFileNotificationHandler(pFile As TRANSMITTALLib.TransmittalFile, _
                                          pTransmit As TRANSMITTALLib.TransmittalOperation) _
            Implements TRANSMITTALLib. _
        Application.DocumentManager.MdiActiveDocument.Editor. _
            WriteMessage(Environment.NewLine & _
                         "File added to transmittal package: " & pFile.sourcePath)
End Class
C#:
// Custom class used to monitor files being added to the transmittal package
internal class MyTransFileNotifier : TransmittalAddFileNotificationHandler
    // Used to get a notification when a drawing or file is added to the transmittal package
    public void addFileNotificationHandler(TRANSMITTALLib.TransmittalFile pFile,
                                           TRANSMITTALLib.TransmittalOperation pTransmit)
            WriteMessage(Environment.NewLine + "File added to transmittal package: " +
                         pFile.sourcePath);
GMT+8, 2026-10-17 22:09
