StandardFileName 属性 (ActiveX/CSP)
2024-5-18 18:34| 发布者: admin| 查看: 709| 评论: 0|原作者: admin|来自: AutoCAD
指定存储修订对象的标准文件的名称。
命名空间:AcStMgr (英语)
集会:AcStMgr.tlb
VB.NET:
object.StandardFileName
C#:
object.StandardFileName;
类型:AcStFix 对象
此属性应用于的对象。
只读:不
类型:字符串
存储修订对象的标准文件的绝对文件路径。
发行信息
释放:AutoCAD 2004 及更高版本
VB.NET:
Public Function GetRecommendedFix(ByVal pError As AcStError) As AcStFix _
                                  Implements IAcStPlugin2.GetRecommendedFix
    Dim pRecommendedFix As New AcStFix()
    ' << Change based on standards implementation >>
    If m_LayerCacheArray.Length = 0 Then
        pError.ResultStatus = AcStResultStatus.acStResNoRecommendedFix
        pRecommendedFix = Nothing
    Else
        ' Get the ObjectId of the error object and the associated layer object
        Dim tmpObjID As Long = pError.BadObjectId()
        Dim tmpLayer As AcadLayer = m_pCheckDatabase.ObjectIdToObject(tmpObjID)
        ' Get the name of the layer
        Dim nameToBeChecked As String = tmpLayer.Name
        tmpLayer = Nothing
        Dim layCache As LayerCache = m_LayerCacheArray(0)
        m_RecommendedFixIndex = -1
        ' Attempt to get the recommended fix from the cached array by matching layer names
        Dim i As Integer
        For i = 0 To UBound(m_LayerCacheArray)
            If m_LayerCacheArray(i).Name = nameToBeChecked Then
                layCache = m_LayerCacheArray(i)
                m_RecommendedFixIndex = i
                ' Exit the For loop after a match is found
                Exit For
            End If
        Next
        ' Validate if a recommended fix was found
        If m_RecommendedFixIndex <> -1 Then
            ' Populate the properties for the recommended fix object
            pRecommendedFix.Description = "Layer fix"
            pRecommendedFix.StandardFileName = m_LayerCacheArray( _
                                               m_RecommendedFixIndex).StandardFileName
            pRecommendedFix.FixObjectName = m_LayerCacheArray( _
                                               m_RecommendedFixIndex).Name
            pRecommendedFix.FixObjectId = m_LayerCacheArray( _
                                               m_RecommendedFixIndex).ObjectId
            If pRecommendedFix.PropertyCount = 0 Then
                pRecommendedFix.PropertyValuePut("Color", m_LayerCacheArray( _
                                                 m_RecommendedFixIndex).Color)
                pRecommendedFix.PropertyValuePut("Lineweight", m_LayerCacheArray( _
                                                 m_RecommendedFixIndex).Lineweight)
            End If
        Else
        End If
    End If
    GetRecommendedFix = pRecommendedFix
End Function
C#:
public AcStFix GetRecommendedFix(AcStError pError)
    AcStFix pRecommendedFix = new AcStFix();
    // << Change based on standards implementation >>
    if (m_LayerCacheArray.Length == 0)
        pError.ResultStatus = AcStResultStatus.acStResNoRecommendedFix;
        pRecommendedFix = null;
    else
        // Get the ObjectId of the error object and the associated layer object
        long tmpObjID = pError.BadObjectId;
        AcadLayer tmpLayer = (AcadLayer)m_pCheckDatabase.ObjectIdToObject(tmpObjID);
        // Get the name of the layer
        string nameToBeChecked = tmpLayer.Name;
        tmpLayer = null;
        AdskLayersPlugin.StandardsHelpers.LayerCache oLayCache = m_LayerCacheArray[0];
        m_RecommendedFixIndex = -1;
        int nLBound = m_LayerCacheArray.GetLowerBound(0);
        int nUBound = m_LayerCacheArray.GetUpperBound(0);
        // Attempt to get the recommended fix from the cached array by matching layer names
        for (int i = nLBound; i <= nUBound; i++)
            if (m_LayerCacheArray[i].Name == nameToBeChecked)
                oLayCache = m_LayerCacheArray[i];
                m_RecommendedFixIndex = i;
                // Exit the For loop after a match is found
                break;
        // Validate if a recommended fix was found
        if (m_RecommendedFixIndex != -1)
            // Populate the properties for the recommended fix object
            pRecommendedFix.Description = "Layer fix";
            pRecommendedFix.StandardFileName = m_LayerCacheArray[m_RecommendedFixIndex].StandardFileName;
            pRecommendedFix.FixObjectName = m_LayerCacheArray[m_RecommendedFixIndex].Name;
            pRecommendedFix.FixObjectId = m_LayerCacheArray[m_RecommendedFixIndex].ObjectId;
            if (pRecommendedFix.PropertyCount == 0)
                pRecommendedFix.PropertyValuePut("Color", (ACAD_COLOR)m_LayerCacheArray[m_RecommendedFixIndex].Color);
                pRecommendedFix.PropertyValuePut("Lineweight", (ACAD_LWEIGHT)m_LayerCacheArray[m_RecommendedFixIndex].Lineweight);
        else
    return pRecommendedFix;
GMT+8, 2026-11-30 19:13
