ResultStatus 属性 (ActiveX/CSP)
2024-5-18 18:34| 发布者: admin| 查看: 627| 评论: 0|原作者: admin|来自: AutoCAD
指定错误的当前状态。
命名空间:AcStMgr (英语)
集会:AcStMgr.tlb
VB.NET:
object.ResultStatus
C#:
object.ResultStatus;
类型:AcStError 对象
此属性应用于的对象。
只读:不
类型:AcStResultStatus 枚举
错误的状态。
发行信息
释放:AutoCAD 2004 及更高版本
VB.NET:
Public Sub FixError(ByVal pError As AcStError, _
                    ByVal pFix As AcStFix, _
                    Optional ByRef pFailedReason As String = "0") _
                    Implements IAcStPlugin2.FixError
    ' << Change based on standards implementation >>
    If IsNothing(pError) = False Then
        Dim sFixClrVal As ACAD_COLOR
        Dim sFixLWVal As ACAD_COLOR
        ' Get the drawing object to fix
        Dim badObjID As Long = pError.BadObjectId
        Dim badObj As AcadLayer = m_pCheckDatabase.ObjectIdToObject(badObjID)
        ' If no fix is provided, try the recommended fix
        If IsNothing(pFix) Then
            Dim tmpFix As New AcStFix()
            tmpFix = GetRecommendedFix(pError)
            If IsNothing(tmpFix) Then
                ' Set the result status of the error to Failed and No Recommended Fix
                pError.ResultStatus = AcStResultStatus.acStResFixFailed + AcStResultStatus.acStResNoRecommendedFix
            Else
                ' Fix the bad object
                pFix = tmpFix
                tmpFix = Nothing
                ' Fix the color of the layer
                pFix.PropertyValueGet("Color", sFixClrVal)
                Try
                    badObj.color = sFixClrVal
                    pError.ResultStatus = AcStResultStatus.acStResFixed
                Catch m_ex As Exception
                End Try
                ' Fix the Lineweight of the layer
                pFix.PropertyValueGet("Lineweight", sFixLWVal)
                Try
                    badObj.Lineweight = sFixLWVal
                End Try
            End If
        Else
            Try
            End Try
            Try
            End Try
        End If
    End If
C#:
public void FixError(AcStError pError, AcStFix pFix, out string pFailedReason)
    // << Change based on standards implementation >>
    if ((pError == null) == false)
        object sFixClrVal = default(ACAD_COLOR);
        object sFixLWVal = default(ACAD_LWEIGHT);
        // Get the drawing object to fix
        long badObjID = pError.BadObjectId;
        AcadLayer badObj = (AcadLayer)m_pCheckDatabase.ObjectIdToObject(badObjID);
        // If no fix is provided, try the recommended fix
        if (pFix == null)
            AcStFix tmpFix = new AcStFix();
            tmpFix = GetRecommendedFix(pError);
            if (tmpFix == null)
                // Set the result status of the error to Failed and No Recommended Fix
                pError.ResultStatus = AcStResultStatus.acStResFixFailed | AcStResultStatus.acStResNoRecommendedFix;
            else
                // Fix the bad object
                pFix = tmpFix;
                tmpFix = null;
                // Fix the color of the layer
                pFix.PropertyValueGet("Color", ref sFixClrVal);
                try
                    badObj.color = (AcColor)sFixClrVal;
                    pError.ResultStatus = AcStResultStatus.acStResFixed;
                catch (Exception m_ex)
                    pError.ResultStatus = AcStResultStatus.acStResFixFailed;
                // Fix the Lineweight of the layer
                pFix.PropertyValueGet("Lineweight", ref sFixLWVal);
                try
                    badObj.Lineweight = (ACAD_LWEIGHT)sFixLWVal;
        else
            try
            try
    pFailedReason = "0";
GMT+8, 2026-10-31 10:35
