Start 方法 (ActiveX/CSP)
初始化错误检查。 支持的平台:仅限 Windows 命名空间:AcStMgr (英语) 集会:AcStMgr.tlb 签名 - AcStErrorIterator 对象仅供内部使用。 VB.NET: object.Start([bShowIgnored]) C#: object.Start([bShowIgnored]);
签名 - IAcStPlugin2 接口VB.NET: Public Sub Start(pStartError) _
Implements IAcStPlugin2.Start
C#: public void Start(pStartError)
返回值 (RetVal)无返回值。 言论没有其他评论。 发行信息释放:AutoCAD 2004 及更高版本
例子VB.NET: Public Sub PlugIn_Start(ByVal pStartError As AcStError) _
' pStartError is not an actual programming error that needs to be handled,
' but a reference to an object that does not match the standards
' in the DWS file.
' If pStartError is an object, checking should start
' from that error, not the beginning of the current context.
If IsNothing(pStartError) = False Then
' Get the ObjectId of the first object to check
Dim badId As Long = pStartError.BadObjectId
' Find the index for ObjectId in the context list stored in m_objIDArray
For m_curIndex = 0 To m_ContextList.Count - 1
If m_ContextList.Item(m_curIndex) = badId Then
m_curIndex = m_curIndex - 1
PlugIn_Next()
End If
Next
Else
' A valid AcStError object was not passed to the method.
' Checking should start at the beginning of the context list.
m_curIndex = -1
PlugIn_Next()
End If
C#: public void PlugIn_Start(AcStError pStartError)
// pStartError is not an actual programming error that needs to be handled,
// but a reference to an object that does not match the standards
// in the DWS file.
// If pStartError is an object, checking should start
// from that error, not the beginning of the current context.
if ((pStartError == null) == false)
// Get the ObjectId of the first object to check
long badId = pStartError.BadObjectId;
// Find the index for ObjectId in the context list stored in m_objIDArray
for (m_curIndex = 0; m_curIndex <= m_ContextList.Count - 1; m_curIndex++)
if (Convert.ToInt64(m_ContextList.GetItem(m_curIndex)) == badId)
m_curIndex = m_curIndex - 1;
PlugIn_Next();
else
// A valid AcStError object was not passed to the method.
// Checking should start at the beginning of the context list.
m_curIndex = -1;
PlugIn_Next();
void IAcStPlugin2.Start(AcStError pStartError)
PlugIn_Start(pStartError);
GMT+8, 2026-10-19 01:04
