IgnoredByApplicationGet 方法 (ActiveX/CSP)
报告应用程序是否忽略错误以及该应用程序的名称。 支持的平台:仅限 Windows 命名空间:AcStMgr (英语) 集会:AcStMgr.tlb 签名VB.NET: object.IgnoredByApplicationGet(bIgnored, appName) C#: object.IgnoredByApplicationGet(ref bIgnored, ref appName);
返回值 (RetVal)无返回值。 言论没有其他评论。 发行信息释放:AutoCAD 2004 及更高版本
例子VB.NET: Public Function GetError() As AcStError Implements IAcStPlugin2.GetError
' Gets the ignore status of an error and outputs the information to the Output window
Dim bFlag As Boolean = False
Dim sName As String = ""
m_pError.IgnoredByApplicationGet(bFlag, sName)
Debug.Print(vbLf + "Ignored status: " + bFlag.ToString() + " App Name: " + sName)
m_pError.IgnoredByUserGet(bFlag, sName)
Debug.Print(vbLf + "Ignored status: " + bFlag.ToString() + " User Name: " + sName)
Return m_pError
End Function
C#: public AcStError GetError()
// Gets the ignore status of an error and outputs the information to the Output window
bool bFlag = false;
string sName = "";
m_pError.IgnoredByApplicationGet(bFlag, sName);
Debug.Print("\nIgnored status: " + bFlag.ToString() + " App Name: " + sName);
m_pError.IgnoredByUserGet(bFlag, sName);
Debug.Print("\nIgnored status: " + bFlag.ToString() + " User Name: " + sName);
return m_pError;
GMT+8, 2026-10-17 21:39
