ObjectAdded 事件 (ActiveX)
在将对象添加到图形时触发。 支持的平台:仅限 Windows 签名VBA: object.ObjectAdded(Entity) 言论显示模式对话框时不会触发任何事件。 例子VBA: Private Sub AcadDocument_ObjectAdded(ByVal Object As Object)
' This example intercepts a drawing ObjectAdded event.
' This event is triggered when an object is added to a drawing.
' To trigger this example event: Add an object to an open drawing
' Use the "Object" variable to determine the type of object added
MsgBox "A " & TypeName(Object) & " was just added to the drawing!"
可视化 LISP: Not available |
GMT+8, 2026-10-17 02:47
