LayoutSwitched 事件 (ActiveX)
在用户切换到其他布局后触发。 支持的平台:仅限 Windows 签名VBA: object.LayoutSwitched(LayoutName)
言论显示模式对话框时不会触发任何事件。 例子VBA: Private Sub AcadDocument_LayoutSwitched(ByVal LayoutName As String)
' This example intercepts a drawing LayoutSwitched event.
' This event is triggered when the user switches to a different
' drawing layout view.
' To trigger this example event: Open a drawing and change its layout view
' For example: Switch the drawing from Model view to Layout1 view
' Use the "LayoutName" variable to determine the which layout view we changed to
MsgBox "The drawing layout was just changed to: " & LayoutName
可视化 LISP: Not available |
GMT+8, 2026-11-29 10:47
