EndOpen 事件 (ActiveX)
2024-5-18 18:34| 发布者: admin| 查看: 649| 评论: 0|原作者: admin|来自: AutoCAD
在AutoCAD打开完现有图形后立即触发。
object.EndOpen(Filename)
类型: 应用
计算结果为有效容器对象的对象表达式。在这种情况下,唯一有效的容器是应用程序。
文件名
类型:字符串
正在打开的文件的名称。
该事件紧跟 AutoCAD 完成现有图形打开后的事件。EndOpen BeginOpen
显示模式对话框时不会触发任何事件。
Public WithEvents ACADApp As AcadApplication    ' Use with Application Event Examples
Sub Example_AcadApplication_Events()
    ' This example intializes the public variable (ACADApp) which will be used
    ' to intercept AcadApplication Events
    ' The VBA WithEvents statement makes it possible to intercept an generic object
    ' with the events associated with that object.
    ' Before you will be able to trigger any of the AcadApplication events,
    ' you will first need to run this procedure.
    ' We could get the application from the ThisDocument object, but that would
    ' require having a drawing open, so we grab it from the system.
    Set ACADApp = GetObject(, "AutoCAD.Application.24")
Private Sub ACADApp_EndOpen(ByVal FileName As String)
    ' This example intercepts an Application EndOpen event.
    ' This event is triggered when AutoCAD finishes opening a drawing.
    ' To trigger this example event:
    '     1) Make sure to run the example that initializes
    '     the public variable (named ACADApp) linked to this event.
    '     2) Use AutoCAD to open an existing drawing and wait until the
    '     operation finishes
    ' Use the "FileName" variable to determine which drawing file is being opened
    MsgBox "A drawing was just loaded from: " & FileName
Not available
GMT+8, 2026-10-24 08:56
