BeginPlot 事件 (ActiveX)
在AutoCAD收到打印图形的请求后立即触发。 支持的平台:仅限 Windows 签名VBA: object.BeginPlot(DrawingName) 言论显示模式对话框时不会触发任何事件。 例子VBA: Private Sub AcadDocument_BeginPlot(ByVal DrawingName As String)
' This example intercepts a drawing BeginPlot event.
' This event is triggered when a drawing receives a plot request.
' To trigger this example event: Plot an open drawing
' Use the "DrawingName" variable to determine which drawing is about to plot
MsgBox "A drawing has just received a request to plot for: " & DrawingName
可视化 LISP: Not available |
GMT+8, 2026-10-27 09:49
