BeginOpen 事件 (ActiveX)
在AutoCAD收到打开现有图形的请求后立即触发。 支持的平台:仅限 Windows 签名VBA: object.BeginOpen(Filename)
言论一旦AutoCAD收到打开现有文件的请求,就会触发该事件。此请求可以由用户通过“文件打开”对话框以交互方式发出,也可以以编程方式发出。BeginOpen 打开 DXF 格式文件时不触发该事件。BeginOpen 打开现有文件时,当 AutoCAD 完成图形的打开时,该事件之后将跟随该事件。例如,当用户选择“应用程序”菜单 创建新文件时,将触发该事件。 NewDrawing 显示模式对话框时不会触发任何事件。 例子VBA: Public WithEvents ACADApp As AcadApplication ' Use with Application Event Examples
Sub Example_AcadApplication_Events()
' This example intializes the public variable (ACADApp) which will be used
' to intercept AcadApplication Events
' The VBA WithEvents statement makes it possible to intercept an generic object
' with the events associated with that object.
' Before you will be able to trigger any of the AcadApplication events,
' you will first need to run this procedure.
' We could get the application from the ThisDocument object, but that would
' require having a drawing open, so we grab it from the system.
Set ACADApp = GetObject(, "AutoCAD.Application.24")
Private Sub ACADApp_BeginOpen(FileName As String)
' This example intercepts an Application BeginOpen event.
' This event is triggered when a drawing is opened by AutoCAD.
' To trigger this example event:
' 1) Make sure to run the example that initializes
' the public variable (named ACADApp) linked to this event.
' 2) Use AutoCAD to open an existing drawing
' Use the "FileName" variable to determine which drawing file is being opened
MsgBox "A drawing is about to be loaded from: " & FileName
可视化 LISP: Not available |
GMT+8, 2026-10-27 21:07
