BeginModal 事件 (ActiveX)
2024-5-18 18:34| 发布者: admin| 查看: 614| 评论: 0|原作者: admin|来自: AutoCAD
在显示模式对话框之前触发。
object.BeginModal()
类型: 应用
计算结果为有效容器对象的对象表达式。在这种情况下,唯一有效的容器是应用程序。
显示模式对话框时不会触发任何事件。
切勿从事件处理程序中为事件发出消息框。BeginModal
Public WithEvents ACADApp As AcadApplication    ' Use with Application Event Examples
Sub Example_AcadApplication_Events()
    ' This example intializes the public variable (ACADApp) which will be used
    ' to intercept AcadApplication Events
    ' The VBA WithEvents statement makes it possible to intercept an generic object
    ' with the events associated with that object.
    ' Before you will be able to trigger any of the AcadApplication events,
    ' you will first need to run this procedure.
    ' We could get the application from the ThisDocument object, but that would
    ' require having a drawing open, so we grab it from the system.
    Set ACADApp = GetObject(, "AutoCAD.Application.24")
Private Sub ACADApp_BeginModal()
    ' This example intercepts an Application BeginModal event.  We use a Beep instead of
    ' a message box to notify the user when the event is triggered, since a message box
    ' is a modal entity and would cause continuous BeginModal/EndModal events to be triggered.
    ' This event is triggered when AutoCAD displays a modal dialog.
    ' To trigger this example event:
    '     1) Make sure to run the example that initializes
    '     the public variable (named ACADApp) linked to this event.
    '     2) Use AutoCAD to begin a modal dialog operation.
    '     For example, use AutoCAD to display a modal file dialog by using File/New
    Beep  ' A modal dialog is about to be displayed!
Not available
GMT+8, 2026-12-1 04:21
