BeginFileDrop 事件 (ActiveX)
2024-5-18 18:34| 发布者: admin| 查看: 789| 评论: 0|原作者: admin|来自: AutoCAD
在应用程序主窗口中拖放文件时触发。
object.BeginFileDrop(FileName, Cancel)
类型: 应用
计算结果为有效容器对象的对象表达式。在这种情况下,唯一有效的容器是应用程序。
文件名
类型:字符串;输入到处理程序
已删除在主应用程序窗口中的文件的名称。
取消
类型:布尔;处理程序的输出
  • True:中止图形的加载。
  • False:允许继续加载图形。
显示模式对话框时不会触发任何事件。
Public WithEvents ACADApp As AcadApplication    ' Use with Application Event Examples
Sub Example_AcadApplication_Events()
    ' This example intializes the public variable (ACADApp) which will be used
    ' to intercept AcadApplication Events
    ' The VBA WithEvents statement makes it possible to intercept an generic object
    ' with the events associated with that object.
    ' Before you will be able to trigger any of the AcadApplication events,
    ' you will first need to run this procedure.
    ' We could get the application from the ThisDocument object, but that would
    ' require having a drawing open, so we grab it from the system.
    Set ACADApp = GetObject(, "AutoCAD.Application.24")
Private Sub ACADApp_BeginFileDrop(ByVal FileName As String, Cancel As Boolean)
    ' This example intercepts an Application BeginFileDrop event.
    ' This event is triggered when a drawing file is dragged into AutoCAD.
    ' To trigger this example event:
    '     1) Make sure to run the example that initializes
    '     the public variable (named ACADApp) linked to this event.
    '     2) Drag an AutoCAD drawing file into the AutoCAD application from either
    '     the Windows Desktop or Windows Explorer
    ' Use the "Cancel" variable to stop the loading of the dragged file, and the "FileName"
    ' variable to notifiy the user which file is about to be dragged in.
    If MsgBox("AutoCAD is about to load " & FileName & vbCrLf & _
              "Do you want to continue loading this file?", vbYesNoCancel + vbQuestion) <> vbYes Then
        Cancel = True
    End If
Not available
GMT+8, 2026-11-29 14:18
